Gear Up Landing Rub Strips
I have been given the responsibility of the design/analysis/testing of our fuselage gear up landing rub strips. These parts are too be designed for the 3g gear up landing with mu = 0.5 with the ground per 14 CFR 23.561(c). My questions are, has anyone here had experience with what the FAA requires for testing/substantiation? Can we utilize small element tests using similar contact pressures and coefficients of friction to determine the wear rate? Or will we need to simulate a full aircraft gear up landing situation? Are there any AC's which I need to be aware of?
Thank you in advance.
Erik
Erik
RE: Gear Up Landing Rub Strips
The problem is not so much in the rub strips as the strength of the structure above the rub strips. Ribs above the strip will need to support the load without catastrophic failure.
