Can Catia Import DWG with....
Hello Everyone,
I am a SolidWorks User.  Have a question about Catia.  Can Catia v5 import a multi-sheet drawing file (dwg/dxf format) as a multisheet drawing file in catia???
If yes then great and if no - then what does it do to it?
Thanks a ton,
vik
RE: Can Catia Import DWG with....
Hello vik,
I believe the multi-sheet is supported since R14 release, but you may verify that as I do not have this release yet.
On R13, I think it just imports all the sheets in one sheet in CATIA V5, you can then cut /paste in another sheet.
