Air/Water compressor
Sorry if this seems like a stupid question, but no one here at work seems to know. is there a compressor avalible that will compress both air and water?
RE: Air/Water compressor
Vita sine litteris mors est.
With any significant amount of liquid you will be better off separating the air and water with a knockout drum, separator, and/or a coalescer, depending on conditions, before sending the air to a compressor.
Your last point is really important. Often, the sealing liquid will react badly with the entrained water and form an emulsion that can smoke the compressor. If you have a lot of liquid that you just can't separate, I like centrifuguls or eductors/ejectors better than screws or liquid rings because the later two are positive displacement and it doesn't take much liquid accumulation to do ugly things.
David
