API 2201 Hot Tapping
Would API 2201 be relevant for refinery pipe hot tapping, or would it fall under ASME B31? Why?
Rick
Rick
RE: API 2201 Hot Tapping
The piping (such as a saddle-on connection) or the special hot tap equipment (such as a split tee) might be designed to B31.x but API 2201 would be consulted for the hot tap procedure. API 2201 also covers the risks involved, required flow rates, preheat, welding minimums/maximums, drilling equipment, etc.
-InspEngr
If so, where is that referenced in API code?
Rick
