CO2 - O2 separtion question
I have a gas stream that is ~70% CO2 and ~70% air.  I would like to recover the CO2 from the stream at a high purity (less than 100PPM Oxygen).   I only need to recover 30-50% of the raw gas stream to make this viable.  Any suggestions on a membrane?  Is there simulation software avilalble to be able to play "what if"?
RE: CO2 - O2 separtion question
Correction to above 70% CO2 & 30% air
The molecular weights : O2=32, N2=28, C02 = 44
I don't think the difference is enough to enable you to
use a membrane separation.
Can't you use the difference in the solubility in H2O ?
<nbucska@pcperipherals.com>
Try using mixed matrix membrane. The membrane contains zeolite on polymer substrate. it works well on the separation of CO2 from N2 and CO2 from O2.
References : "Gas permeation characteristics of polymer-zeolite mixed matrix membranes" Journal of membrane science (1994), 91, pp 77 and " A new composite membrane for selective transport of gases" in Proceedings of the 6th international symposium on synthetic membranes in science and indeustry, Germany, 1989
Try using cryogenics.  This is routinely done for air pre purification.
