Printing in a mosaic
First
I need to print 6 parts at 1:1 scale on 8.5 X 11 sheet so they can be used as templates for tracing the parts out (woodworking).
Second
These parts are bigger than an 8.5 X 11 sheet of paper. So some sort of a mosaic will have to be done. With each sheet contaning a section of the part and then the sheets will be tapped together to form 1 sheet with the part at full scale. I hope I explained that ok.
Is this possible with SW? If so how does one do this? Utimatly I need the sheets saved as .pdf's.
I'm sure this is not the easiest way to do it but it's how the customer wants it done.
SW 2005 SP0.0
Second
SW 2005 SP0.0
RE: Printing in a mosaic
I would place items in a drawing format that will allow a 1:1. Then I would use Bluebeam to create a PDF at 1:1. Then if you have a full blown version of Adobe you should be able to print in four quads. I remember doing this once while using Pro/e their print utility Pro/Plot had an option to do this. best of luck
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
plus... sketch some crop line on the drawing so you can match up the edges
