Electric Generators for Wind Turbines
I have a wind turbine on the drawing boards that I want to prototype this summer. It is a Vertical Axis WT, sized to produce about 1kW (I hope). I expect it to turn more slowly than typical VAWT's (just based on some analysis at this point), something like 60 RPM, with lots of torque instead (lots and lots of torque).
Does anyone have suggestions about selecting generators for it? I'm a bit out of my expertise on the electrical side.
On the safety side, I'm thinking of using an old disc brake from my car to stop it when necessary. Can this be done electrically instead? (or does that just cause a safety problem of its own?)
Thanks, in advance, for any help you can offer.
Steven Fahey, CET
RE: Electric Generators for Wind Turbines
our paper was just making a big fuss over the birds killed by Altamont Pass wind farms in CA. Expurts were arguing as to the actual numbers/year which ran from 400 to 6,000.. (Come on what's the actual number?!?!)
At any rate that's an interesting project you have. The disk brake is an excellant idea though I wouldn't use the one off your car. :) One problem is that your average disk brakes are hydralic which isn't real good for emergency/maintenance applications due to hydralic leak down. You might look for a mechanical disc brake like the type used on cars for the rear parking brake feature.
Next the cheapest generator would be a vehicle alternator. Fairly reliable too. But you haven't stated what you are going to do with the power. Do you need 12VDC or 120VAC? Are you going to try running household appliance stuff or only garage or workshop or??? There are many different possibilities out there. Some cheap some expensive, but truly effective.
More info please.
http://wind.dynalias.com/indexg.html
The alternative - DC - is a bit easier because, as you say, auto (or aero) alternators are easy to come by and already designed for the task at hand. What should I choose to load a DC generator? Adding an inverter to go back to the light bulb idea would work, but it's more complicated and the power loss thru the inverter gets in the way of measuring the turbine's performance.
Any other opinions on the topic are very welcome!
The point of the project is to find a way to get over the "self-starting" problem that Darrieus and other vertical axis WT's have. I have a few alternatives in mind, and I want to create a turbine that I can adapt to try a variety of solutions. I won't claim that all of the ideas are my own - some come from a few university papers that I've read.
Mechanical brakes - Maybe the disc brakes from a mountain bike or motorcycle would be more appropriate.
Thanks byrdj for the link.
Steven Fahey, CET
Okay you're using it for research..
I have used the lightbulb method myself. It works well but it has some problems in your case. Remember you generally need to keep an AC generator running at one speed. This is why most small wind or water generators run DC generators so the frequency/speed control is removed from the whole process.
I would think you would be MUCH better served with a 12VDC car alternator that you gear way up with a single belt. So the alternator spins about 2,000-3,000RPM
Then you run the output to a large rheostat that you can *continuously* vary, unlike light bulbs.
You stick an ammeter in the line, and a voltmeter across the rheostat.
From these two meters you just multiply their two readings together and you have the windmills power output.
Later if you want to see *light* either stick in one or more headlights or ? You can also stick in an inverter and create your 120VAC without the really large mucking about with trying to accurately control the mill's speed.
You said 1000W. You need an alternator rated at 1000W/12V = 84AMPS So find one rated at 100Amps, a pretty common value.
The rheostat will take a little looking around to find for cheap but they exist. I have two and didn't pay for either.
htt
ht
http://www.jenkins.com/jenkins/controls/ohmite.htm
Oh yeah the brake ... A good large diameter mountain bike mechanical disk brake would probably work. Personally I would use a car rear mechanical disk brake from a junkyard and I would grab the brake application lever out of the car too. As this would be one less thing you have to fabricate. A car's applicator will be self locking something a bicycle will not be. This would let you click on *some* brake and if it's a car brake it will take a whole lot of abuse. For instance, build your mill with the car brake and you can run it a bit by just applying a few clicks of brake drag. Once that is all working you can proceed to the generator angle.
Never heard of a rheostat that can dissipate 1kW. Not your garden-variety Radio Shack volume knob. I'll follow your links and see what they've got.
Thanks a lot!
Steven Fahey, CET
I've been searching about VAWT's for a while, I'm considering a VAWT but with a variable diameter in order to increase tork and reducing the speed.
I agree with the DC alternator option and wish you luck
Please let us know about your development
Sounds like a fun project.
Oh, and you may need more than 3000RPM to get 1000W from a car alternator. If you can take high frequency AC, you can disconnect the internal rectifiers and bring the winding leads out directly. The windings are 3-phase.
Yeah alehman is correct you probably would want to spin the alternator at least 4,000RPM.
Speaking of using light bulbs for loads.... been-there-done-that!
Seriously!!
Here's a few shots to spice up your day.. or night.
I was asked to build a 14 channel power PID controller.
Each channel was 1000 Watts.
I wanted to test it before delivery.
How to test it...hmmmm
14,000 Watts....hmmm
What's cheap?
Costco light bulbs!!
I picked up 140 of them.
I wasn't about to socket that many so I soldered to the base and tie-wrapped to the threads pigtails. Then I lumped 10 into one wire pair for each channel. 1000 Watts each ta-da!
Here's a front pic of a 19 inch rack mount power controller I designed and built from scratch.
I did it at home, when my spare bedroom was a laboratory. (Now I have a commercial place.)
Here's a top view of the controller. SSR city. I also had current monitoring of each channel, a master contactor, fault lights, happy lights, fault lock out, communications and a multiloop controller. Temp sensors were thermocouples.
Here are the light bulbs.. during the day.
I learned many things.. Like 14kW is a lot of heat! After running for 30 seconds the solder would start melting on the bulbs in the middle of clusters... this would cause the hot leads to spring off, easily finding the threaded bulb bases and instantly shorting. The controller got fault tested!!
This lead to the use of a large fan and careful bulb spacing. Note the trailer hitch wire hold down and the trusty waffle iron load cell. :)
At night it was spectacular.. This picture doesn't do it any justice at all because the camera stopped way down to get the shot. 14kW of lamps lit up the 120ft Redwood tree down the street so brightly that its true color was present. When these lamps started modulating it was breathtaking.
The unit tested okay and I ended up making about 40 of them.
So yes light bulbs do work, but are a pain to set up.
The big problem with Darius and other vertical machines is as you say, the low operating Rpm, and the high torque. One system I have seen was to use a complete car rear axle with one side removed from the differential. That will give you a vertical pillar with a brake and sturdy bearing at the top. The handbrake cable can be used to lock the system when required, and the brake drum will keep the rain out to a certain extent if it is sealed with silicone.
The system I saw was a Savonius made from cut down 55 gallon oil drums mounted on long pipe arms.
At the base, the original differential spider gears can be welded up. The crown wheel and pinion will give you a very high torque right-angle drive output with an initial speed step up of around 3:1 to 4:1
The diff will also provide a strong locating point for a very large diameter drive pulley (or sprocket) to run your car alternator at a suitable speed. Hint, a bicycle chain is going to be more efficient at this than a V belt.
It might all look a bit agricultural, but it will be very robust and low cost, and well within the capabilities of a good practical handyman.
A Savonius rotor can generate huge torque if the buckets are mounted on long arms. The car axle solves a lot of the mechanical problems, and it could all be done almost for zero cost too.
Hi alehman,
They use those controllers in the machines that make flat panel displays. There is a process phase where you must heat the large thin glass sheets to a closely controlled temp before depositing chamical layers on them. The *ovens* are 13 shelves (14 heaters) in a vacuum chamber that the glass pauses in to be heated. The sheets of glass where 30" X 30". The latest are now 60" x 72" and about 1/16" thick. Nice and fragile and all handled in a vacuum by robots.
http://www.odysen.com/forums/viewforum.php?f=117
Hope it could be useful for you
Very impressive photo's. Very nice applicaton to the 100w (X 14) bulb load. In addition whats that thingy next to the "waffel Iron" looks like a electromag device.
BTW are you located out West? Cause I seen this brite light back awhile ago.
I can imagine the bulbs clinking together from the fan air and then breaking too! Well you made it work and thats what counts. Good on you.
Best Regards
pennpoint
I'm 75mi south of San Francisco. heheh
Actually many times the bulbs clacked together I would flinch but I never lost one.
Oh, the hose just lives there I wouldn't dream of spraying it on an electrical conflagration. I'd use that 30# Purple-K dry extinguisher in the shed door, to the left (red).
mexelec; THAT is a nice forum...
Thanks for bringing up a lot of fun ideas. Warpspeed, I see you're familiar with both the Darrieus and Savonius VAWT designs. Have you come across any alternative types? Each of the above two have weaknesses, and I'm playing with mathematical models of a design that will overcome them.
I also like the suggestion of using an auto rear axle - my concept drawing isn't that different, fundamentally.
Steven Fahey, CET
Steven Fahey, CET
As standard, they are omni-directional in that they are used to run the motor, but not use power from an overhauling motor to feed back to the line. There are "regenerative" VFDs, but because they are back-to-back inverters they are essentially twice the price and twice the losses. Some VFDs can be fed with DC, so with a DC power source and a little creativity they can be used as an inverter, but a plain inverter would cost you less, so why?
BTW, back to your question as to how to put a load on a DC generator? Light bulbs don't know the difference between AC and DC, only the voltage level fed to them. So if you get your hands on a 12V generator, just go buy some 12V light bulbs. Many hardware stores carry them, marine and RV accessory stores as well. From a proof-of-concept standpoint you want the most direct route from turine to load, so any kind of electronic device in between will add losses that may interfere with your results.
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more."
Nikola Tesla
Savonius rotors are self starting, simple, and easy to make and are probably the easiest and cheapest for a do it yourself project. As the fuel (wind) is free, overall mechanical efficiency is probably not as important as it may at first seem. Another aspect is repair of storm damage. It is not going to be a complete disaster if a fifty dollar junk wind machine gets completely demolished.
Darius rotors are much more high tech, but supporting it at the top is a problem never that easy to solve.
For feeding power back into the grid, the best system I have seen used a dc wind machine and battery, coupled to a fully bi-directional sinewave inverter. This inverter being a stepped sinewave of typically thirty steps.
These inverters are truly bi-directional and can easily handle reactive loads very effectively because of that feature. Also the ratio of dc/ac input/output voltage is continually variable so they make excellent battery chargers. They can also supply a fully regulated ac voltage from a varying dc source.
Maybe I should slap a savonius type of turbine together, just for the sake of getting the electrical system working, and then go on to my other ideas. That would avoid side-tracking on problem "B" in the middle of Project "A".
Like I said - electricity isn't my strong suit.
Thanks so far everybody!
Steven Fahey, CET
Shortly after these postings, I started building. I now have two rotors running, though not yet producing electricity. My focus has been on the machinery, as there were lessons to be learned about bearing losses, vibration, and aerodynamic performance first.
I built a 2-foot high model in my garage over a weekend to start, and played around with it for a month. Actually, it's still running, but I'm now working on the third machine.
Again, thanks for the ideas, folks.
Steven Fahey, CET
I built a HAWT machine last year. We average around 4m/s wind speed in this area so one goal was to build an efficient machine. Even though the wind is free you have to build a less efficient machine with a larger swept area to get the same output as a machine with a better efficiency.
One big advantage for a HAWT that doesn't seem to get mentioned is the fact that the height of the machine can make or break it. Your machine should be about 30' above any ground obstacles for best wind coverage. To me, putting a HAWT on a 50' to 100' guyed tower seems simpler than doing the same with a VAWT. If I was looking at putting an equivalent output Savonius VAWT on my tower I'd have to put up a much heavier tower.
The best generators for a wind machine are permanent magnet 3-phase types. Driving the field of a car alternator could use up a fair bit of the power you're gathering, especially in low wind conditions.
The trick here is to find smoothly rising ground for perhaps a mile upwind. The wind speed will then be fairly high right down at ground level. I have seen some wonderful Savoinus systems mounted only just off the ground in coastal areas where a steady onshore breeze blows up a smoothly rising grassy slope right from the beach.
Another ideal location is the dip in a "saddle" between two smooth grassy hills. The wind blows around the hills as well as over the top. The dip between two large hills can make a terrific wind site, and the wind speed can be high right down at ground level.
Conditions are not always that fortunate, and if there are a lot of large trees and other significant ground objects up wind, a high tower may be required to get above all the slow turbulent air near the ground.
I agree that a permanent magnet high voltage alternator will definitely be more efficient, but how would you control the output voltage ? I suppose a three phase rectifier and a PWM buck regulator to bring the voltage back down would be the simplest and most obvious way to control the output. A rather interesting idea.
You're right about the possible site locations but I'm not that lucky here. There's just enough wind to run a mill in this area so I wanted to build a good machine to take advantage of the little wind there is.
I believe a Savonius type blade design has a max theoretical efficiency of about 31% while a HAWT propeller type blade design has a max theoretical efficiency of about 59%. If you've got the wind it doesn' matter but since my wind was limited I wanted to start with the most efficient design possible.
You control the output of a permanent magnet generator by two possible means;
On a smaller machine you just charge batteries. Then, you use an actual load, such as a grid tied inverter, or a dump load to control the battery voltage.
On a larger machine, from what I've read, it seems that the output is being rectified into a DC buss and then a grid tied inverter is used for the utility connection. I'd imagine the inverter is used to control the DC buss voltage much like a VFD with an active front end can control the buss voltage.
I believe every windmill smaller than about 10kW (and many larger ones too) presently being sold uses a permanent magnet generator so the permanent magnet generator is definately the most popular.
If you guys want some interesting reading check out the site www.otherpower.com or the magazine at www.homepower.com
Given the distance to the house, I've been thinking (idly, it's a long way in the future) that I could step-up AC to a transmission line strung on the nearby utility poles already going that way, and then stepping down again at the garage. Then put in the rectifier/inverter/whatever, as necessary.
I'm building something to fiddle with, at this point, so I don't want it up on a tower. If this homebrewed contraption evolves to the point that it produces useful work, it may be triumphantly raised aloft.
A few more months of research has led me to conclude that adapting automotive technology risks being extremely wasteful. Renewable energy fanatics like to wind their own motor/generators, and many favour 3-phase, and let the voltage drift with RPM, usually because they're converting it to DC to charge batteries anyway. I may go the same way, if I get to the point of putting the VAWT to practical use. Since all I want to do at this point is to collect comparative data which I can use to make performance calculations, a simple DC motor, a multimeter, and a few 12V light bulbs will do nicely.
Here's video of what I've produced so far:
http:
The white one on the right is a double cup "savonius", while the one on the left is a two-blade "darrieus". I made the Darrieus blades by sawing vertically down a piece of plywood, at a steep angle to produce a bevelled edge on both, and rounded the LE. So far, it only runs at a TSR of 0.7, not 1.5 or 2, like other VAWTs, and definitely not 5 or 6, like typical HAWTs, but it's pretty crude, after all. It's taught me a lot, in spite of all that.
Great input, so far, guys, thanks.
Steven Fahey, CET
