compile error?
compile error?
compile error?
Program line: Dim fso As New FileSystemObject
When I excute an MVB program I got an error message:
"User-defined type not defined".
What did I not defined, please help.
RE: compile error?
The FileSystemObject is not defined.  You need to add a reference to the Scripting Runtime objects into the project.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
