Heat exchangers with double walls
I'd like to size a HX with double-walled tubes. There would be two separate header sheets and each tube would be inside another tube.
Is there any way to do it in B-JAC?
Thank you.
Thank you.
RE: Heat exchangers with double walls
The last time I used B-Jac, all configurations were relative to the TEMA standards. As was also HTRI. Good luck on finding the configuration. But then, why do you need to do it on a computer program? Why no do it the old fashioned way - manually. I would trust the manual method more, since it is transparent in its logic and algorithm. B-Jac and other computer programs aren't.
I'll circumvent the problem by using an equivalent thickness for the inner tube.
Thanks anyway.
