30" Ductile Iron Unit cost
Anyone have a unit cost for 30" Ductile iron pipes?
RE: 30" Ductile Iron Unit cost
contact your local pipe supplier.  No local supplier ?  Contact ANY supplier.  No telephone?
In PA, USA, today, per:
http://www.get-a-quote.net/QuoteEngine/costbook.asp?WCI=CostFrameSet&;BookId=55
2005 Pennsylvania Heavy Construction Costs:  Page 206
Mechanical joint ductile iron pipe, no fittings included
No excavation or backfill included, using a 20-ton hydraulic crane with 70' boom and two sets of small tools.
CSI 02-453    Craft@Hrs    Unit    Material    Labor    Equip    Total
30" (76cm)    xu@.410    LF    76.4    10.1    2.33    88.83
Add for short runs (60' or less)    ---@---    %    10    100
90 degree elbows for mechanical joint ductile iron pipe
Using a 20-ton hydraulic crane with 70' boom and small tools.
30" (76cm) diameter    xu@9.90    Ea    2940    243    56.2    3239.2
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Thank you!
-Phil
