Color Transfer
Color Transfer
I was mirroring some components in an assembly about a center datum plane in which each component were given different color (to differentiate the material), it did mirror but not the color of components and gives some different colors (I think default color). Is there anyway by which color could also be transferred while doing the mirroring option. Version: pro/e 2001. Thanks,Raj.
RE: Color Transfer
You set colors at assembly level then it gives the new ones the default color..least under r2001.. wf might handle it better
RE: Color Transfer
