REPLACE LOST TOOLBAR ICON
hi,
I've been searching the forum and was surprised I couln't find an answer to this question, I've had the same problem before, but I can't remember the solution...
I deleted a toolbar icon (UCS by face) from my custom toolbar. I thought it was a copy from the standard UCS ACAD set, but apparently I neglected to copy it when I moved it to my custom bar. Now it's gone from the UCS toolbar group.
How do I restore it?
sundemon
RE: REPLACE LOST TOOLBAR ICON
take a look at your acad.mns file your custom toolbar should be wrtten in there, once you've found it, type in the missing command.
Adam
Thanks for responding, but I'm a little confused.
I'm trying to replace the "UCS face" command and icon on the standard-issue ACAD USC toolbar, as opposed to my custom toolbar.
Looking in the menu.mns file, I find an entry for the UCSface command, so no need to type it in...
Now how do I actually go about restoring the deleted icon and tool?
thanks, SD
Have you created custom icons before?
you need to Right click on the UCS toolbar, add a custom button in the usual way by dragging a custom button onto the tool bar, select the properties tab, click on you new user defined button, enter the name/discription, then the macro should read ^C^C_ucs _fa
not sure if that's the correct way to restore the tool bar....but it does work.
thanks, adamwildon.
Not the most elegant solution, but it did work. I had to re-draw the icon from memory, I guess when I deleted the toolbar the original icon went with it.
Do you know where the file for all the standard tool icons can be found?
after searching, no sorry. I could copy mine and send you the icon if you would like.  I wish I could tell you more but I'm a command line person really, don't tend to use icons.
Adam
All of my icons are contained in a Support file folder in the ACAD program file.
yes but you should check all the "documents and settings" folders, autocad is using the heck out of those.
Alex
