3D Vehicle Surface Models
Does anyone know where i can find  3 dimensional CAD models
of Chevy, Dodge, Ford trucks. i only need the exterior surfaces.
RE: 3D Vehicle Surface Models
Join SEMA, at the manufacturer level.  Thru their "Tech Transfer" program, you might be able to get the data.  You'll need to fill out some paperwork, explain what you want the data for, etc., and see if the OEM will give it to you via SEMA.
http://www.sema.org
-Dave
Everything should be designed as simple as possible, but not simpler.
Thanks Gunman for the info.
grigter07
