Property for toolbox part number
In SolidWorks 2005 it is possible to add a part number, description and comment for toolbox parts in the toolbox database. Our PDM-ystem can automaticly link toolbox parts with the matching Item data but it needs to read the part number out of the file properties.
Is there a property defined for this part number in SolidWorks and how can I link it to a custom property?
Thanks in advance,
Marc
Thanks in advance,
Marc
RE: Property for toolbox part number
Inside SolidWorks, check Toolbox->Browser Configuration->Browser tab-Custom Properties
SolidMold
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
I'm looking for a solution that makes the part number available in a file property. Anny ideas?
Marc
Please Note: Make sure you remove the read-only rights from each fastener before performing this task.
There may be a better way to do this but for now this is all I can think of.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
We use ProfiDB as PDM-system and it needs a custom property with the value of the part number assigned to the toolbox part. Therefore I can't use $PRP:"SW-Configuration Name".
Marc
