Human Powered Generator-Motor Efficiency
Is there a paper discussing the best human powered (pedal) generator to motor efficiency combination?
RE: Human Powered Generator-Motor Efficiency
Welcome to the Eng-Tips forum, djsmisc.
One of the tools available to you here is the "Search Posts (Keyword)" search option in the little drop-down box above. Subjects such as this have often been discussed before, the trick is to try different ways of searching for it. I happened to remember that a similar subject came up some time ago. Click on this link below and you will be taken to that old thread. Look at the link at the end of the thread posted by IRStuff. It is not specific to your question, but there is a reference list of around 50 other related papers shown at the end of it that might prove useful.
thread240-116567
You may also want to post this question in the Eng-Tips forum entitle "Energy conversion engineering". Those folks are a little more up on these issues than we are.
Good luck.
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more."
Nikola Tesla
Can you explain the application a little better.
It sounds like you want to start with mechanical power (pedaling), convert to electrical power (generator action), and convert back to mechanical power (motor action).  In general (if you don't need to store the energy), you will get higher efficiency without the conversion to electrical... use gears or belt as necessary to match your torque or speed requirements.
