sending data between VBA and lisp
Hi all.
Can anyone help me with an ongoing problem?  I'm using a vba form called from lisp, but am having trouble passing data back to lisp from this form.
I have used the users1-s5 variables successfully in the past but this particular form has about 20 input fields that I need to feed back.  Anyone found a solution for a similar problem?
RE: sending data between VBA and lisp
how about writing to a temporary file ?
just write the data out in vba
read the data in via Lisp
kill the temporary file
or string the items together in a single list, then use one of the USERSx variable to hold the single string (list) then you will need to parse the list when reading it back in
http://www.resourcecad.com ~ for your CAD solutions
Thanks Hendie.
Yeah, I'm currently writing out to a temp text and then reading/deleting this temp file within lisp.  I've thought of the single list option too, but for reasons too complicated to explain simply it got too messy.
I was hoping to find a simple solution that could take place within acad (ie, no external file needed) but I can't seem to find a solution.  It's one of those problems that I know other people must have faced before but I can't seem to find a single instance mentioned anywhere online.
Thanks for your thoughts though.
