350 psi electrical connector for a pressure vessel
I'm looking to pass data through the wall of a pressure vessel (350 psig) via a multi-pin connector (brad harrison type). Any companies to suggest with a good reputation?
RE: 350 psi electrical connector for a pressure vessel
Check out these two:
http:
http://www.pavetechnologyco.com/html/library.html
Good Luck
pennpoint
http
Amphenol likely has an equivalent.
http://www.seaconbrantner.com/
No problem
We tend to use Seacon and Burton...
