Unit weight of Soil
Unit weight of Soil
Unit weight of Soil
I'm not familiar with earth science, but could someone help me out with this questions. I need to know the unit weight of soil based on the description of the soil composition. Specifically, a value expressed in lbs/ft^3 for two soil descriptions:
1) Loose to medium dense sands and gravel; soft clays and silt
2) Dense to very dense sand and gravel.
A "ballpark" value will be sufficient or maybe point me to references that I can get accessed to them easily. Any help would greatly be appreciated.
Many Thanks.
Dean
RE: Unit weight of Soil
Dean - Go to my web site (link below) and download "US Steel Sheet Piling Design Extracts". Look in Table 6.
Best Wishes
www.SlideRuleEra.net
1)  IF dry 2320 lbs/cu-ft  If wet 2600 lbs/cu-ft
2)  If dry 2500 lbs/cu-ft  If wet 2700 lbs/cu-ft
mitchell54
Don't you mean pounds per cubic yard, NOT per cubic foot !?
If so your weights sound pretty light.
Of course, one could always go out, get a box full of the soil and weigh it.  But that would mean leaving the office and missing all those important phone calls and emails.
good luck
Use a value of 100 to 115 pcf or so for clays and silts...
and,
120 to 130 pcf for sand and gravel
Correction:
Your weights sound pretty HEAVY !
Your soil is about 40 times the weight of water ( 62.4 lbs/cu ft )  Lead weighs about 13 times as much as water.
good luck looking up answers in books
