Using countours as a dwg in GIS
I currently am working with a project where a dam failed and am interested in material (sediment, trees) displaced by the failure. Assuming I can do this, I currently have in my possession...
Elevation data from 1998 (pre-breach) as a DEM
Elevation data from last month (post-breach) as a DWG
Aerial from 98 & post-breach
The problem is that I do not know how to get the DWG into something I can work with in ArcGIS 8.X. I have tried converting in Arctoolbox, to no avail. I am using LT 2005, but I am unable to export to anything but a DXF or wmf, obviously. I have access to LDD, wold that help?
Anyhow, I am thinking I can create a 3D surface for visual impact and maybe another in LDD to get a volume. Any suggestions?
R Hardison
R Hardison
RE: Using countours as a dwg in GIS
I believe you can export the surfaces and/ or contour data using Autodesk Map (built in to LDD). Under the Map menu choose Tools>Export... Then pick the file type Ie. ESRI ArcInfo Export or ESRI Shape. (I have LDD 2004.)
You could also import the aerial photography into LDD to help set your surface model boundaries (Ie distrubed areas). I am not familar with ArcGIS8.x, but you can probably run some type of change detection with the aerials/ DEMS using an ESRI product.
Hope this is helpful.
Dustin
Santa Rosa, CA
