Resizing --dust(powder) to granule--
Hi friends,
We have an material which is in powder form and,I am looking for an equipment[s] which can be capable of resizing powder to granule size. I hope there exists a pratic and simple way of this process.
RE: Resizing --dust(powder) to granule--
There are many kinds of different agglomerators and the choice depence on capacity of processing,properties of your material and on the target properties and price of your product: particle size distribution, uniformity, the amount and sort of a binder and some other properties like flowability, stability, rate of dissolution, final moisture content etc. If you are dealing with a pharmaceutical product in a range of maybe hundreed kg/day you will probably use more expencive and complex technology batch process(fluid bed agglomerator)compared to a continuous fertilizer agglomerator with a few tons/hour output.
Search the web!
regards
m777182
You might also look at pelletizers. We have experimented with pelletizers to control the rate of some heterogeneous reactions.
Goodluck
Stonecold
