SW 2005 SP 4.0 Released
RE: SW 2005 SP 4.0 Released
Why is it EV?  Isn't that short for evaluation or something?
Flores
It doesn't show 4.0 as released. 3.1 is the latest
Macduff
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
Yes.  But the download should be the full SP release.  (There must have been a 4.0EV release as well, so there is an option for upgrading from that SP as well as the previous SPs.)
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Whoops--started typing before macduff's post was visible.
I didn't see SP 4.0 listed in the SPR fix list page, but the SP I downloaded was 4.0 and not 4.0EV.
Jeff Mowry
What new in SP4.0?
thx
Industrial Designer
SW2005 SP3.1
Not sure yet.  Still working on a project, so I've neither installed it nor seen the release notes.  For what it's worth, what's new isn't supposed to be disclosed publicly, so we'll need to wait for the relase notes to be published or to install to find out.
Jeff Mowry
SP 4.0 is released as of yesterday. I wonder why I didn't see it when this thread was posted?
Anyone running it yet?
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
There are quite a few fixes in the latest SP. I have read through a few of them but don't really have time to read all of them. This is one of the bigger SP releases I have seen so far.
One noteable feature I found with this SP is that the measure tool now has a pink selection box, which enables you to see what items you have selected.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
Cool.  I'll need to put this project to bed and install the SP.  You'll need to update your sig line.
Jeff Mowry
Anyone running SP4.0 yet? Any known bugs? I'm running it and everything seems to be A OK.
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
...I'm also running it with no problems.
Brian
Finally got it installed and have no problems.
Jeff Mowry
So far so good......
This has got to be one of the biggest SP's in some time, I counted over 300 fixes.
 "The squeaky wheel gets greased"
Flores
SP4.0 seams stable to me......
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
another question...........
any you guys using sp 4.0 with solidworks and pdmworks vault? Is it stable too?
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
yes we are using the 4.0 SP with the PDM Works vault and it is much more stable for us.
Best Regards,
Jon
Macduff,
We are using SolidWorks 2005 SP4 with PDM Works 0.0
It has been stable for us, although I do crash every now and then.
Bradley
Got mine installed, but where do you find out what the differences are? The only mention of it that I could find is only 4 paragraphs long, and there must be more to it than that.
Had some strange issues with hatch patterns since upgrade
Example opened an existing drawing to find hatch pattern has changed angle in some views
Any one seen this??
I have not had that but hole callout quit working.  Calls all holes and taps as geometry.  Have not done a lot of investigation yet to see what the problem might else be.
Yeah!   You can now see the numbers for "spacing" and "number of instances" in the pattern of a PART in an ASSEMBLY.  This problem has been brought up a couple of times, so I thought I would mention that they fixed it.
Flores
