default dim diplay to be nominal instead of limits
Does anyone know how to make the default dimension style "Nominal" instead of "Limits".  I couldn't seem to find a drawing setup parameter for this.
thanks
RE: default dim diplay to be nominal instead of limits
tol_mode
nominal, limits, plusminus, plusminussym
Sets the default display for dimension tolerances. If set to nominal, displays dimensions without tolerances. If set to limits, displays them as upper and lower limits. If set to plusminus, displays them as nominal with plus-minus tolerances (the positive and negative values are independent). If set to plusminussym, displays them as nominal with a single value for both the positive and the negative tolerance.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 3.1 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
thanks for both quick responses, that helped.
