Rear Diffusser Design For Race Car?
Hello
Can anyone answer this please?
I need to manufacture a rear diffusser for a Supercar/Race Car.
In plan view does the trailing edge of the diffusser need to be straight, or can it be curved?
Many thanks
Marcus
Many thanks
Marcus
RE: Rear Diffusser Design For Race Car?
good luck
-Dave
Everything should be designed as simple as possible, but not simpler.
Something else you all may be-able to shed some light on:
If the diffuser angle is too steep, does the air stall?
What do you think is the max angle?
Thanks for the help
Marcus
I think too much angle causes seperation and turbulance, which kills the efficientcy. The number of strakes will make a difference too. My understanding is they help clean up the turbulant air from the rear tires. I've noticed the C6R's, running alot more strakes in the diffuser, and Prodrive always seemed to use alot.
-Dave
Good luck,
Wes C.
-Dave
Hanley has a couple design programs for wings - check his website.
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
