return of function values in Excel
I would like to know if it is possible to get 2 or 3 values from the same function that was generated in the VBA Editor from Excel.
If it is, how could i do it?
RE: return of function values in Excel
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Your function should return an array of values, so it's going to be an array function. For example:
Public Function test() As Variant
test = Array(1, 2, 3)
End Function
To retrieve the test values in the spreadsheet select cells
A1:C1, then type =test() and press Ctrl-Shift-Enter.
If you stay within VB, the correct way for returning multiple values is to declare the function as returning a user defined type (a 'structure').
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
