Run-time error in engine heat release rate program
I am getting a run-time error when trying to compile my program and as I
am not very experienced in Fortran I am not sure what the error is or how
to fix it. The program has been lifted out of a book called "Interneal
Combustion Engines:Applied Thermosciences" and is a program to model the
heat release rate of a an engine. It requires a couplke of subroutines,
DVERK and LEQIF which are IMSL routines and I do not have. I have found
the code for DVERK but unfortunately have not found the code for LEQIF
which is why I assume I am receiving the run-time error. the error is a
zero or negative argument to a logarithm routine.
FARG - in file release2_good.for at line 664 [+1738]
main - in file release2_good.for at line 41 [+0190]
The main code is listed below and any help in resolving this matter would
be greatly appreciated.
Chris
C GIVEN IN BLOCK DATA SUBPROGRAM
C COMPRESSION RATIO - R
C BORE - B (CM)
C STROKE - S (CM)
C HALF-STROKE TO ROD RATIO - EPS
C ENGINE SPEED - RPM
C HEAT TRANSFER COEFFICIENT - H (J/S/M**2/K)
C BLOWBY COEFFICIENT - C (L/S)
C EQUIVALENCE RATIO - PHI
C RESIDUAL FRACTION - F
C INITIAL PRESSURE - P1 (BAR)
C INITIAL TEMPERATURE - T1 (K)
C WALL TEMPERATURE - TW (K)
C BURN ANGLE - THETAB (DEG)
C START OF HEAT RELEASE - THETAS (DEG ATDC)
C
C FIND:
C INDICATED THERMAL EFFICIENCY - ETA
C INDICATED MEAN EFFECTIVE PRESSURE - IMEP (BAR)
C
C NOTES:
C 1. COSINE BURNING LAW IS EMPLOYED, EQN. 4.61
C ` 2. FUEL - GASOLINE (C7H17)
C
EXTERNAL RATES
REAL IMEP, MNOT, M
COMMON /ENGINE/ R, B, S, EPS, RPM, H, C, THETAB, THETAS,
& PHI, F, P1, T1, TW, MNOT, OMEGA, UNOT, UFINAL
DIMENSION Y1(6), Y2(10), Y(6), COM(24), WM(6,9)
DATA AO/47870./, FS/.06548/, Y/1., 10000., 350., 3*0.0/,
& N/6/, THETA/-180./, THETAE/-179./, TOL/.001/, IND/1/,
& NW/6/, PI/3.141593/, Y2/10*0.0/
C
C LABEL HEADER ON OUTPUT PAGE AND PRINT INITIAL CONDITIONS
C
OMEGA = RPM*PI/30
CALL AUXLRY(THETA, V, X, EM)
Y(1) = P1
Y(3) = T1
CALL FARG(Y(1), Y(3), PHI, F, HU, U, VU, SU, Y1, CP, DLVLT,
& DLVLP)
MNOT = V/VU
UNOT = MNOT*U
WRITE(6,10)
10 FORMAT(5X,'THETA',4X,'VOLUME',3X,'BURN FRAC',2X,'PRESSURE',3X,
& 'BURN TEMP',2X,'T UNBURN',3X,'WORK',3X,'HEAT LOSS',5X,
& 'MASS',3X,'H-LEAK')
WRITE(6,15)
15 FORMAT(4X,'DEG ATDC',2X,'CM**3',6X,'--',8X,'BARS',7X,'KELVIN',
& 5X,'KELVIN',3X,'JOULES',4X,'JOULES',6X,'GRAMS',2X,
& 'JOULES')
WRITE(6,20) THETA, V, X, (Y(I),I=1,5), MNOT, Y(6)
20 FORMAT(4X,F5.0,6X,F5.0,4X,F5.3,6X,F5.2,7X,F5.0,5X,F5.0,
& 5X,F5.0,3X,F5.0,7X,F5.3,3X,F5.2)
C
C INTEGRATE THE RATE EQUATIONS 4.80 - 4.85 AND PRINT ANSWERS
C EVERY 10 DEGREES
C
DO 30 I = 1,36
DO 25 J = 1,10
CALL DVERK (N, RATES, THETA, Y, THETAE, TOL, IND, COM, NW, WM)
CALL AUXLRY(THETAE, V, X, EM)
M = EM*MNOT
THETA = THETAE
THETAE = THETA + 1.
IF(THETAS .GE. THETA .AND. THETAS .LT. THETAE)
& CALL TINITL(Y(1), T(3), PHI, F, Y(2))
IF(THETA .GT. THETAS + THETAB) Y(3) = 10000.
25 CONTINUE
WRITE(6,20) THETA, V, X, (Y(J),J=1,5), M, Y(6)
30 CONTINUE
C
C COMPUTE AND WRITE THE EAT, IMEP AND ERRORS
C
CALL ECP(Y(1), Y(2), PHI, HB, U, VB, SB, Y2, CP, DLVLT, DLVLP,
& IER)
UFINAL = U*M
ERROR1 = 1.0 - VB*M/V
ERROR2 = 1.0 + Y(4)/(UFINAL - UNOT + Y(5) + Y(6))
ETA = Y(4)/MNOT*(1. + PHI*FS*(1. - F))/PHI/FS/(1. - F)/AO
IMEP = Y(4)/(PI/4.*B**2*S)*10.
WRITE(6,40) ETA, IMEP, ERROR1, ERROR2
40 FORMAT('ETA = ',1PE11.4,' IMEP = ',1PE11.4,'ERROR1 = ',1PE11.4,
& ' ERROR2 = ',1PE11.4)
STOP
END
C
SUBROUTINE RATES(N, THETA, Y, YPRIME)
REAL Y(N), YPRIME(N), M, MNOT
COMMON /ENGINE/ R, BORE, STROKE, EPS, RPM, HEAT, CEE, THETAB,
& THETAS, PHI, F, P1, T1, TW, MNOT, OMEGA, UNOT,
& UFINAL
DATA PI/3.141593/, Y2/10*0.0/
M = EM*MNOT
RAD = THETA*PI/180.
DUMB = SQRT(1. - (EPS*SIN(RAD))**2)
DV = PI/8.*BORE**2*STROKE*SIN(RAD)*(1. + EPS*COS(RAD)/DUMB)
A = (DV + V*CEE/OMEGA)/M
C1 = HEAT*(PI*BORE**2/2. + 4.*V/BORE)/OMEGA/M/10000.
C0 = SQRT(X)
C
C THREE DIFFERENT COMPUTATIONS ARE REQUIRED DEPENDING
C UPON THE SIZE OF THE MASS FRACTION BURNED
C
IF( X .GT. .999 ) GO TO 20
IF( X .GT. .001 ) GO TO 10
C
C COMPRESSION
C
CALL FARG(Y(1), Y(3), PHI, F, HL, U, VU, S, Y1, CP, DLVLT,
& DLVLP)
B = C1*VU/CP*DLVLT*(1.0 - TW/Y(3))
C = 0.
D = 0.
E = VU**2/CP/Y(3)*DLVLT**2 + 10.*VU/Y(1)*DLVLP
YPRIME(1) = (A + B + C)/(D + E)*10.
YPRIME(2) = 0.
YPRIME(3) = -C1/CP*(Y(3) - TW) + VU/CP*DLVLT*YPRIME(1)/10.
GO TO 30
C
C COMBUSTION
C
10 CALL FARG(Y(1), Y(3), PHI, F, HU, U, VU, S, Y1, CPU, DLVLTU,
& DLVLP)
CALL ECP(Y(1), Y(2), PHI, HB, U, VB, S, Y2, CPB, DDLVLTB,
& DLVLPB, IER)
B = C1*(VB/CPB*DLVLTB*C0*(1. - TW/Y(2)) + VU/CPU*DLVLTU*
& (1. - C0)*(1.- TW/Y(3)))
DX = 0.5*SIN(PI*(THETA - THETAS)/THETAB)*180./THETAB
C = -(VB - VU)*DX - VB/Y(2)*DLVLTB*(HU - HB)/CPB*(DX - (X -
& X**2)*CEE/OMEGA)
D = X*(VB**2/CPB/Y(2)*DLVLTB**2 + 10.*VB/Y(1)*DLVLPB)
E = (1. - X)*(VU**2/CPU/Y(3)*DLVLTU**2 + 10.*VU/Y(1)*DLVLPU)
HL = (1.0 - X**2)*HU + X**2*HB
YPRIME(2) = -C1/CPB/C0*(Y(2) - TW) + VB/CPB*DLVLTB*
& YPRIME(1)/10. + (HU - HB)/CPB*(DX/X - (1. - X)*
& CEE/OMEGA)
YPRIME(3) = -C1/CPU/(1. + CO)*(Y(3) - TW) + VU/CPU*DLVLTU*
& YPRIME(1)/10.
GO TO 30
C
C EXPANSION
C
20 CALL ECP(Y(1), Y(2), PHI, HL, U, VB, S, Y2, CP, DLVLT, DLVLP,
& IER)
B = C1*VB/CP*DLVLT*(1. - TW/Y(2))
C = 0.
D = VB**2/CP/Y(2)*DLVLT**2 + 10.*VB/Y(1)*DLVLP
E = 0.
YPRIME(2) = -C1/CP*(Y(2) - TW) + VB/CP*DLVLT*YPRIME(1)/10.
YPRIME(3) = 0.
C
C ALL CASES
C
30 YPRIME(4) = Y(1)*DV/10.
YPRIME(5) = C1*M*(C0*(Y(2) - TW) + (1. - C0)*(Y(3) - TW))
YPRIME(6) = CEE*M/OMEGA*HL
DO 40 I = 1,N
40 YPRIME(I) = YPRIME(I)*PI/180.
RETURN
END
C
SUBROUTINE AUXLRY(THETA, V, X, EM)
& PHI, F, P1, T1, TW, EMNOT, OMEGA, UNOT, UFINAL
DATA PI/3.141593/
RAD = THETA*PI/180.
VTDC = PI/4.*B**2*S/(R - 1.)
V = VTDC*(1. + (R - 1.)/2.*(1. - COS(RAD) + 1./EPS*(1. -
& SQRT(1. - (EPS*SIN(RAD))**2))))
X = 0.5*(1. - COS(PI*(THETA - THETAS)/THETAB))
IF(THETA .LE. THETAS) X = 0.
IF(THETA .GE. THETAS + THETAB) X = 1.
EM = EXP(-C*(RAD + PI)/OMEGA)
RETURN
END
C
BLOCK DATA
DATA R/10./, B/10./, S/8./, EPS/.25/, RPM/2000./, H/500./,
& C/0.8/, THETAB/60./, THETAS/-35./, PHI/0.8/, F/.1/,
& P1/1.0/, T1/350./, TW/420./
C
END
C
SUBROUTINE TINITL(P, TU, PHI, F, TB)
DATA MAXITS/50/, TOL/.001/, Y2/10*0.0/
TB = 2000.
CALL FARG(P, TU, PHI, F, HU, U, V, S, Y1, CP, DLVLT, DLVLP)
DO 10 I = 1,MAXITS
CALL ECP(P, TB, PHI, HB, U, V, S, Y2, CP, DLVLT, DLVLP, IER)
DELT = (HU - HB)/CP
TB = TB + DELT
IF(ABS(DELT/TB) .LT. TOL) RETURN
10 CONTINUE
WRITE(6,20)
20 FORMAT('CONVERGENCE FAILURE IN TINITL')
RETURN
END
SUBROUTINE ECP (P, T, PHI, H, U, V, S, Y, CP, DLVLT, DLVLP, IER)
C
C PURPOSE:
C COMPUTE THE PROPERTIES OF EQUILIBRIUM COMBUSTION
C PRODUCTS
C
C GIVEN:
C P - PRESSURE (BARS)
C T - TEMPERATURE )K)
C PHI - FUEL AIR EQUIVALENCE RATIO
C
C RETURNS:
C H - ENTHALPY (J/G)
C U - INTERNAL ENERGY (J/G)
C V - SPECIFIC VOLUME (CM**3/G)
C S - ENTROPY (J/G/K)
C Y - A TEN DIMENSIONAL COMPOSITION VECTOR OF
C MOLE FRACTIONS
C 1=CO2. 2=H2O, 3=N2, 4=O2, 5=CO, 6=H2
C 7=H, 8=O, 9=OH, 10=NO
C CP - SPECIFIC HEAT AT CONSTANT PRESSURE (J/G/K)
C DLVLT - DERIVATIVE OF LOG VOLUME WITH RESPECT TO LOG
C TEMPERATURE AT CONSTANT PRESSURE
C DLVLP - DERIVATIVE OF LOG VOLUME WITH RESPECT TO LOG
C PRESSURE AT CONSTANT TEMPERATURE
C IER - AN ERROR MESSAGE
C 0 - NORMAL
C 1 - CONVERGENCE FAILURE: COMPOSITION LOOP
C 2 - CALLED WITH TOO HIGH AN EQUIVALENCE RATIO; C(S)
C AND OTHER SPECIES WOULD FORM
C
REAL M, MW, K, KP, MT, MP
LOGICAL CHECK
DIMENSION M(10), K(6), C(6), Y(10), D(3), B(4), A(4,4), Y0(6),
& KP(5,6), DFDT(4), DCDT(6), DKDT(6), DCDP(6),
& DYDT(10), DYDP(10), A0(7,10), DFDP(4), CP0(10),
& H0(10), S0(10), WK(12)
C
C FUEL DATA
C
DATA ALPHA/7.0/, BETA/17.0/, GAMMA/0./, DELTA/0./
C
C SPECIFIC HEAT DATA FROM GORDON AND MCBRDE (1971)
C
DATA A0/
1 .44608041E+01, .30981719E-02, -.12392571E-05, .22741325E-09,
1 -.15525954E-13, -.48961442E+05, -.98635982E+00,
2 .27167633E+01, .29451374E-02, -.80224374E-06, .10226682E-09,
2 -.48472145E-14, -.29905826E+05, .66305671E+01,
3 .28963194E+01, .15154866E-02, -.57235277E-06, .99807393E-10,
3 -.65223555E-14, -.90586184E+03, .61615148E+01,
4 .36219535E+01, .72518264E-03, -.19652228E-06, .36201558E-10,
4 -.28945627E-14, -.12019825E+04, .36150960E+01,
5 .29840696E+01, .14891390E-02, -.57899684E-06, .36201558E-10,
5 -.69353550E-14, -.14245228E+05, .63479156E+01,
6 .31001901E+01, .51119464E-03, .52644210E-07, -.34909973E-10,
6 .36945345E-14, -.87738042E+03, -.19629421E+01,
7 .25000000E+01, 0., 0., 0., 0., .25471627E+05, -.46011763E+00,
8 .55420596E+01, -.27550619E-04, -.31028033E-08, .45510674E-11,
8 -.43680515E-15, .29230803E+03, .49203080E+01,
9 .29106427E+01, .95931650E-03, -.19441702E-06, .13756646E-10,
9 .14224542E-15, .39353815E+04, .54423445E+01,
# .31890000E+01, .13382281E-02, -.52899318E-06, .95919332E-10,
# -.64847932E-14, .98283290E+04, .67458126E+01/
C
C EQUILIBRIUM CONSTANT DATA FROM OLIKARA AND BORMAN (1975)
C
DATA KP/
1 .432168E+00, -.112464E+05, .267269E+01, -.745744E-04,
1 .242484E-08,
2 .310805E+00, -.129540E+05, .321779E+01, -.738336E-04,
2 .344645E-08,
3 -.141784E+00, -.213308E+04, .853461E+00, .355015E-04,
3 -.310227E-08,
4 .150879E-01, -.470959E+04, .646096E+00, .272805E-05,
4 -.154444E-08,
5 -.752364E+00, .124210E+05, -.260284E+01, .259556E-03,
5 -.162687E-07,
6 -.415302E-02, .148627E+05, -.475746E+01, .124699E-03,
6 -.900227E-08/
C
C MOLECULAR WEIGHTS
C
DATA M/44.01, 18.02, 28.008, 32., 28.01, 2.018, 1.009, 16.,
& 17.009, 30.004/
C
C OTHER DATA
C
DATA MAXITS/100/, TOL/3.0E-05/, RU/8.31434/
C
C MAKE SURE SOLID CARBON WILL NOT FORM
C
IER = 2
EPS = .210/(ALPHA + 0.25*BETA - 0.5*GAMMA)
IF(PHI .GT. (.210/EPS/(0.5*ALPHA - 0.5*GAMMA)) ) RETURN
IER = 0
C
C DECIDE IF AN INITIAL ESTIMATE TO THE COMPOSITION IS
C REQUIRED OR IF T<1000 IN WHICH CASE FARG WILL SUFFICE
C
C
SUM = 0
DO 10 I = 1,10
10 SUM = SUM + Y(I)
IF( T .GT. 1000. .AND. SUM .GT. 0.998) GO TO 20
CALL FARG(P,T,PHI,1.,H,U,V,S,Y0,CP,DLVLT,DLVLP)
DO 30 I = 1,10
30 Y(I) = 0
DO 40 I = 1,6
40 Y(I) = Y0(I)
IF( T .LE. 1000. ) RETURN
20 CONTINUE
C
C
C EVALUATE THE REQUISITE CONSTANTS
C
PATM = .9869233*P
DO 50 I = 1,6
50 K(I) = 10.**(KP(1,I)*ALOG(T/1000.) + KP(2,I)/T + KP(3,I) +
& KP(4,I)*T + KP(5,I)*T*T)
C(1) = K(1)/SQRT(PATM)
C(2) = K(2)/SQRT(PATM)
C(3) = K(3)
C(4) = K(4)
C(5) = K(5)*SQRT(PATM)
C(6) = K(6)*SQRT(PATM)
D(1) = BETA/ALPHA
D(2) = (GAMMA + .42/EPS/PHI)/ALPHA
D(3) = (DELTA + 1.58/EPS/PHI)/ALPHA
C
C
C SET UP ITERATION LOOP FOR NEWTON-RAPHSON ITERATION AND
C INTRODUCE TRICK TO PREVENT INSTABILITIES NEAR PHI = 1.0
C AT LOW TEMPERATURES ON 24 BIT MACHINES (VAX). SET
C TRICK = 1.0 ON 48 BIT MACHINES (CDC)
C
TRICK = 10.
CHECK = ABS(PHI - 1.0) .LT. TOL
IF(CHECK) PHI = PHI*(1.0 + SIGN(TOL,PHI - 1.0))
ICHECK = 0
DO 5 J = 1,MAXITS
DO 4 JJ = 1,10
4 Y(JJ) = AMIN1(1.0,AMAX1(Y(JJ),1.0E-25))
D76 = 0.5*C(1)/SQRT(Y(6))
D84 = 0.5*C(1)/SQRT(Y(4))
D94 = 0.5*C(3)*SQRT(Y(6)/Y(4))
D96 = 0.5*C(3)*SQRT(Y(4)/Y(6))
D103 = 0.5*C(4)*SQRT(Y(4)/Y(3))
D104 = 0.5*C(4)*SQRT(Y(3)/Y(4))
D24 = 0.5*C(5)*Y(6)/SQRT(Y(4))
D26 = C(5)*SQRT(Y(4))
D14 = 0.5*C(6)*Y(5)/SQRT(Y(4))
D15 = C(6)*SQRT(Y(4))
A(1,1) = 1. + D103
A(1,2) = D14 + D24 + 1. +D84 + D104 + D96
A(1,3) = D15 + 1.0
A(1,4) = D26 + 1.0 + D76 +D96
A(2,1) = 0.0
A(2,2) = 2.0*D24 + D94 - D(1)*D14
A(2,3) = -D(1)*D15 - D(1)
A(2,4) = 2.0*D26 + 2.0 + D76 + D96
A(3,1) = D103
A(3,2) = 2.0*D14 + D24 + 2.0 + D84 + D04 + D104 - D(2)*D14
A(3,3) = 2.0*D15 + 1.0 - D(2)*D15 - D(2)
A(3,4) = D26 + D96
A(4,1) = 2.0 +D103
A(4,2) = D104 - D(3)*D14
A(4,3) = -D(3)*D15 - D(3)
A(4,4) = 0
C
C SOLVE THE MATRIX EQUATIONS 3.81 FOR COMPOSITION CORRECTIONS
C
SUM = 0
DO 55 I = 1,10
55 SUM = SUM + Y(I)
B(1) = -(SUM - 1.0)
B(2) = -(2.0*Y(2) + 2.0*Y(6) + Y(7) + Y(9) - D(1)*Y(1) -
& D(1)*Y(5))
B(3) = -(2.0*Y(1) + Y(2) + 2.0*Y(4) + Y(5) + Y(8) + Y(9)
& + Y(10) - D(2)*Y(1) - D(2)*Y(5))
B(4) = -(2.0*Y(3) + Y(10) - D(3)*Y(1) - D(3)*Y(5))
CALL LEQIF(A, 4, 4, 4, B, 4, 1, 0, WK, IERROR)
ERROR = 0.
DO 56 L = 3,6
LL = L - 2
Y(L) = Y(L) + B(LL)/TRICK
ERROR = AMAX1(ERROR,ABS(B(LL)))
Y(L) = AMIN(1.0,AMAX(Y(L),1.0E-25))
56 CONTINUE
Y(7) = C(1)*SQRT(Y(6))
Y(8) = C(2)*SQRT(Y(4))
Y(9) = C(3)*SQRT(Y(4)*Y(6))
Y(10) = C(4)*SQRT(Y(4)*Y(3))
Y(2) = C(5)*SQRT(Y(4))*Y(6)
Y(1) = C(6)*SQRT(Y(4))*Y(5)
IF(ERROR .LT. TOL) ICHECK = ICHECK +1
IF(ERROR .LT. TOL .AND. ICHECK .GE. 2) GO TO 57
5 CONTINUE
IER = 1
C
C COMPUTE THE REQUISITE CONSTANTS TO FIND PARTIAL DERIVATIVES
C
57 DO 60 I = 1,6
60 DKDT(I) = 2.302585*K(I)*(KP(1,I)/T - KP(2,I)/T/T + KP(4,I)
& + 2.0*KP(5,I)*T)
DCDT(1) = DKDT(1)/SQRT(PATM)
DCDT(2) = DKDT(2)/SQRT(PATM)
DCDT(3) = DKDT(3)
DCDT(4) = DKDT(4)
DCDT(5) = DKDT(5)*SQRT(PATM)
DCDT(6) = DKDT(6)*SQRT(PATM)
DCDP(1) = -0.5*C(1)/P
DCDP(2) = -0.5*C(2)/P
DCDP(5) = 0.5*C(5)/P
DCDP(6) = 0.5*C(6)/P
C
X1 = Y(1)/C(6)
X2 = Y(2)/C(5)
X7 = Y(7)/C(1)
X8 = Y(8)/C(2)
X9 = Y(9)/C(3)
X10 = Y(10)/C(4)
DFDT(1) = DCDT(6)*X1 + DCDT(5)*X2 + DCDT(1)*X7 +DCDT(2)*X8
& + DCDT(3)*X9 + DCDT(4)*X10
DFDT(2) = 2.0*DCDT(5)*X2 + DCDT(1)*X7 + DCDT(3)*X9 -
& D(1)*DCDT(6)*X1
DFDT(3) = 2.0*DCDT(6)*X1 + DCDT(5)*X2 + DCDT(2)*X8
& + DCDT(3)*X9 + DCDT(4)*X10 - D(2)*DCDT(6)*X1
DFDT(4) = DCDT(4)*X10 - D(3)*DCDT(6)*X1
DFDP(1) = DCDP(6)*X1 + DCDP(5)*X2 + DCDP(1)*X7 + DCDP(2)*X8
DFDP(2) = 2.0*DCDP(5)*X2 + DCDP(1)*X7 - D(1)*DCDP(6)*X1
DFDP(3) = 2.0*DCDP(6)*X1 + DCDP(5)*X2 + DCDP(2)*X8 -
& D(2)*DCDP(6)*X1
DFDP(4) = -D(3)*DCDP(6)*X1
C
C SOLVE THE MATRIX EQUATIONS 3.91 FOR THE INDEPENDENT DERIVATIVES
C AND THEN DETERMINE THE DEPENDENT DERIVATICES
C
DO 70 I = 1,4
70 B(I) = -DFDT(I)
CALL LEQIF(A, 4, 4, 4, B, 4, 1, 1, WK, IERROR)
DYDT(3) = B(1)
DYDT(4) = B(2)
DYDT(5) = B(3)
DYDT(6) = B(4)
DYDT(1) = SQRT(Y(4))*Y(5)*DCDT(6) + D14*DYDT(4) + D15*DYDT(5)
DYDT(2) = SQRT(Y(4))*Y(6)*DCDT(5) + D24*DYDT(4) + D26*DYDT(6)
DYDT(7) = SQRT(Y(6))*DCDT(1) + D76*DYDT(6)
DYDT(8) = SQRT(Y(4))*DCDT(2) + D84*DYDT(4)
DYDT(9) = SQRT(Y(4)*Y(6))*DCDT(3) + D94*DYDT(4) + D96*DYDT(6)
DYDT(10) = SQRT(Y(4)*Y(3))*DCDT(4) + D104*DYDT(4) + D103*DYDT(3)
C
DO 80 I = 1,4
80 B(I) = -DFDP(I)
DYDP(3) = B(1)
DYDP(4) = B(2)
DYDP(5) = B(3)
DYDP(6) = B(4)
DYDP(1) = SQRT(Y(4))*Y(5)*DCDP(6) + D14*DYDP(4) + D15*DYDP(5)
DYDP(2) = SQRT(Y(4))*Y(6)*DCDP(5) + D24*DYDP(4) + D26*DYDP(6)
DYDP(7) = SQRT(Y(6))*DCDP(1) + D76*DYDP(6)
DYDP(8) = SQRT(Y(4))*DCDP(2) + D84*DYDP(4)
DYDP(9) = D94*DYDP(4) + D96*DYDP(6)
DYDP(10) = D104*DYDP(4) + D103*DYDP(3)
C
DO 90 I = 1,10
CP0(I) = A0(1,I) + A0(2,I)*T + A0(3,I)*T*T + A0(4,I)*T**3
& + A0(5,I)*T**4
H0(I) = A0(1,I) + A0(2,I)/2.*T + A0(3,I)/3.*T*T + A0(4,I)/4.*
& T**3 + A0(5,1)/5.*T**4 + A0(6,I)/T
90 S0(I) = A0(1,I)*ALOG(T) + A0(2,I)*T + A0(3,I)/2.*T**2
& + A0(4,I)/3.*T**3 + A0(5,I)/4.*T**4 +A0(7,I)
C
C Y(1), Y(2) ARE REEVALUATED TO CLEAN UP ANY ROUND-OFF ERRORS WHICH
C CAN OCCUR FOR THE LOW TEMPERATURE STOICHIOMETRIC SOLUTIONS
C
Y(1) = (2.*Y(3) + Y(10))/D(3) - Y(5)
Y(2) = (D(1)/D(3)*(2.*Y(3) + Y(10)) - 2.*Y(6) - Y(7) - Y(9))/2
C
MW = 0.
CP = 0.
H = 0.
S = 0.
MT = 0.
MP = 0.
DO 100 I = 1,10
IF( Y(I) .LE. 1.0E-25 ) GO TO 100
H = H + H0(I)*Y(I)
MW = MW + M(I)*Y(I)
MT = MT + M(I)*DYDT(I)
MP = MP + M(I)*DYDP(I)
CP = CP + Y(I)*CP0(I) + H0(I)*T*DYDT(I)
S = S + Y(I)*(S0(I) - ALOG(Y(I)))
100 CONTINUE
C
R = RU/MW
V = 10.*R*T/P
CP = R*(CP - H*T*MT/MW)
DLVLT = 1.0 + AMAX1(-T*MT/MW,0.)
DLVLP = -1.0 - AMAX1(P*MP/MW,0.)
H = H*R*T
S = R*(-ALOG(PATM) + 5)
U = H - R*T
RETURN
END
C
C
SUBROUTINE FARG (P, T, PHI, F, H, U, V, S, Y, CP, DLVLT, DLVLP)
C
C PURPOSE:
C COMPUTE THE PROPERTIES OF A FUEL, AIR, RESIDUAL
C GAS MIXTURE
C
C GIVEN:
C T - TEMPERATURE (K)
C F - RESIDUAL MASS FRACTION
C
C RETURNS:
C V - SPECIFIC VOLUME (CM**3/g)
C Y - A SIX DIMENSIONAL COMPOSITION VECTOR OF
C MOLE FRACTIONS
C 1=CO2, 2=H2O, 3=N2, 4O2, 5=CO, 6=H2
C
C REMARKS:
C 1. VALID FOR 300 < T < 1000
C 2. ASSUMES THE FUEL IS GASOLINE
C 3. ENTHALPIES OF O2, H2, N2 AND C(S) ARE SET TO ZERO
C AT 298K
C 4. THE FUEL MOLE FRACTION IS UNITY MINUS THE SUM OF Y(I)
C
REAL M, MW, MRES, MFA, MFUEL, K, NU, N2
LOGICAL RICH, LEAN
DIMENSION A(7,6), TABLE(6), M(6), NU(6), Y(6), CP0(6), H0(6),
& S0(6)
C
C FUEL DATA
C
DATA ALPHA/7.0/, BETA/17.0/, GAMMA/0./, DELTA/0./,
& A0/4.0652/, B0/6.0977E-02/, C0/-1.8801E-05/,
& D0/-3.5880E+04/, E0/15.45/
C
C TABLE 3.1, I = 1,6
C
DATA A/
1 .24007797E+01, .87350957E-02, -.6607878E-05, .20021861E-08,
1 .63274039E-15, -.48377527E+05, .96951457E+01,
2 .40701275E+01, -.11084499E-02, .41521180E-05, -.29637404E-08,
2 .80702103E-12, -.30279722E+05, -.32270046E+00,
3 .36748261E+01, -.12081500E-02, .23240102E-05, -.63217559E-09,
3 -.22577253E-12, -.10611588E+04, .23580424E+01,
4 .36255985E+01, -.18782184E-02, .70554544E-05, -.67635137E-08,
4 .21555993E-11, -.10475226E+04, .43052778E+01,
5 .37100928E+01, -.16190964E-02, .36923594E-05, -.20319674E-08,
5 .23953344E-12, -.14356310E+05, .29555355E+01,
6 .30574451E+01, .26765200E-02, -.58099162E-05, .55210391E-08,
6 -.18122739E-11, -.98890474E+03, -.22997056E+01/
C
C OTHER DATA
C
DATA RU/8.315/, TABLE/-1.,1.,0.,0.,1.,-1./, M/44.01, 18.02,
& 28.008, 32.000, 28.01, 2.018/
C
C COMPUTE RESIDUAL GAS COMPOSITION ACCORDING TO TABLE 3.3
C
RICH = PHI .GT. 1.0
LEAN = .NOT. RICH
DLVLT = 1.0
DLVLP = -1.0
EPS = .21/(ALPHA + 0.25*BETA - 0.5*GAMMA)
IF (RICH) GO TO 10
NU(1) = ALPHA*PHI*EPS
NU(2) = BETA*PHI*EPS/2
NU(3) = 0.79 + DELTA*PHI*EPS/2
NU(4) = 0.21*(1.0 - PHI)
NU(5) = 0.
NU(6) = 0.
DCDT = 0.
GO TO 20
10 Z = 1000./T
K = EXP(2.743 + Z*(-1.761 + Z*(-1.611 + Z*.2803)))
DKDT = -K*(-1.761 + Z*(-3.222 + Z*.8409))/1000.
A1 = 1.0 - K
B = .42 - PHI*EPS*(2.*ALPHA - GAMMA) + K*(.42*(PHI - 1.) +
& ALPHA*PHI*EPS)
C = -.42*ALPHA*PHI*EPS*(PHI - 1.0)*K
NU(5) = (-B + SQRT(B*B - 4.*A1*C))/2./A1
DCDT = DKDT*(NU(5)**2 - NU(5)*(.42*(PHI - 1.) + ALPHA*
& PHI*EPS) + .42*ALPHA*PHI*EPS*(PHI - 1.))/
& (2.*NU(5)*A1 + B)
NU(1) = ALPHA*PHI*EPS - NU(5)
NU(2) = .42 - PHI*EPS*(2.*ALPHA - GAMMA) + NU(5)
NU(3) = .79 + DELTA*PHI*EPS/2.
NU(4) = 0.
NU(6) = .42*(PHI - 1.) - NU(5)
C
C COMPUTE MOLE FRACTIONS AND MOLECULAR WEIGHT OF RESIDUAL
C
20 TMOLES = 0.
DO 30 I = 1,6
30 TMOLES = TMOLES + NU(I)
MRES = 0.
DO 40 I = 1,6
Y(I) = NU(I)/TMOLES
40 MRES = MRES + Y(I)*M(I)
C
C COMPUTE MOLE FRACTIONS AND MOLECULAR WEIGHT OF FURLE-AIR
C
FUEL = EPS*PHI/(1. + EPS*PHI)
O2 = .21/(1. + EPS*PHI)
N2 = .79/(1. + EPS*PHI)
MFA = FUEL*(12.01*ALPHA + 1.008*BETA + 16.*GAMMA + 14.01*
& DELTA) + 32.*O2 + 28.02*N2
C
C COMPUTE MOLE FRACTIONS OF FUEL-AIR-RESIDUAL GAS
C
YRES = F/(F + MRES/MFA*(1. - F))
DO 50 I = 1,6
50 Y(I) = Y(I)*YRES
YFUEL = FUEL*(1. - YRES)
Y(3) = Y(3) + N2*(1. - YRES)
Y(4) = Y(4) + O2*(1. - YRES)
C
C COMPUTE COMPONENT PROPERTIES
C
DO 60 I = 1,6
CP0(I) = A(1,I) + A(2,I)*T + A(3,I)*T**2 + A(4,I)*T**3 +
& A(5,I)*T**4
H0(I) = A(1,I) + A(2,I)/2.*T + A(3,I)/3.*T**2 + A(4,I)/4.*
& T**3 + A(5,I)/5.*T**4 + A(6,I)/T
60 S0(I) = A(1,I)*ALOG(T) + A(2,I)*T + A(3,I)/2.*T**2 +
& A(4,I)/3.*T**3 + A(5,I)/4.*T**4 + A(7,1)
C
MFUEL = 12.01*ALPHA + 1.008*BETA + 16.000*GAMMA + 14.01*DELTA
CPFUEL = A0 + B0*T + C0*T**2
HFUEL = A0 + B0/2.*T + C0/3.*T**2 + D0/T
S0FUEL = A0*ALOG(T) + B0*T + C0/2.*T**2 + E0
C
C COMPUTE PROPERTIES OF MIXTURE
C
H = HFUEL*YFUEL
S = (S0FUEL - ALOG(YFUEL))*YFUEL
CP = CPFUEL*YFUEL
MW = MFUEL*YFUEL
DO 70 I = 1,6
H = H + H0(I)*Y(I)
CP = CP + CP0(I)*Y(I) + H0(I)*T*TABLE(I)*DCDT*YRES/TMOLES
70 MW = MW + Y(I)*M(I)
C
R = RU/MW
H = R*T*H
U = H - R*T
V = 10.*R*T/P
S = R*(-ALOG(.9869*P) + S)
CP = R*CP
C
RETURN
END
C
C
SUBROUTINE DVERK(N, FCN, X, Y, XEND, TOL, IND, C, NW, W)
INTEGER N, IND, NW, K
DOUBLE PRECISION X, Y(N), XEND, TOL, C(*), W(NW,9), TEMP
C Added external statement for fcn to avoid a warning message.
external fcn
C
C***********************************************************************
C *
C PURPOSE - THIS IS A RUNGE-KUTTA SUBROUTINE BASED ON VERNER'S *
C FIFTH AND SIXTH ORDER PAIR OF FORMULAS FOR FINDING APPROXIMATIONS TO *
C THE SOLUTION OF A SYSTEM OF FIRST ORDER ORDINARY DIFFERENTIAL *
C EQUATIONS WITH INITIAL CONDITIONS. IT ATTEMPTS TO KEEP THE GLOBAL *
C ERROR PROPORTIONAL TO A TOLERANCE SPECIFIED BY THE USER. (THE *
C PROPORTIONALITY DEPENDS ON THE KIND OF ERROR CONTROL THAT IS USED, *
C AS WELL AS THE DIFFERENTIAL EQUATION AND THE RANGE OF INTEGRATION.) *
C *
C VARIOUS OPTIONS ARE AVAILABLE TO THE USER, INCLUDING DIFFERENT *
C KINDS OF ERROR CONTROL, RESTRICTIONS ON STEP SIZES, AND INTERRUPTS *
C WHICH PERMIT THE USER TO EXAMINE THE STATE OF THE CALCULATION (AND *
C PERHAPS MAKE MODIFICATIONS) DURING INTERMEDIATE STAGES. *
C *
C THE PROGRAM IS EFFICIENT FOR NON-STIFF SYSTEMS. HOWEVER, A GOOD *
C VARIABLE-ORDER-ADAMS METHOD WILL PROBABLY BE MORE EFFICIENT IF THE *
C FUNCTION EVALUATIONS ARE VERY COSTLY. SUCH A METHOD WOULD ALSO BE *
C MORE SUITABLE IF ONE WANTED TO OBTAIN A LARGE NUMBER OF INTERMEDIATE *
C SOLUTION VALUES BY INTERPOLATION, AS MIGHT BE THE CASE FOR EXAMPLE *
C WITH GRAPHICAL OUTPUT. *
C *
C HULL-ENRIGHT-JACKSON 1/10/76 *
C *
C *
C USE - THE USER MUST SPECIFY EACH OF THE FOLLOWING *
C *
C N NUMBER OF EQUATIONS *
C *
C FCN NAME OF SUBROUTINE FOR EVALUATING FUNCTIONS - THE SUBROUTINE *
C ITSELF MUST ALSO BE PROVIDED BY THE USER - IT SHOULD BE OF *
C THE FOLLOWING FORM *
C SUBROUTINE FCN(N, X, Y, YPRIME) *
C INTEGER N *
C DOUBLE PRECISION X, Y(N), YPRIME(N) *
C *** ETC *** *
C AND IT SHOULD EVALUATE YPRIME, GIVEN N, X AND Y *
C *
C X INDEPENDENT VARIABLE - INITIAL VALUE SUPPLIED BY USER *
C *
C Y DEPENDENT VARIABLE - INITIAL VALUES OF COMPONENTS Y(1), Y(2), *
C ..., Y(N) SUPPLIED BY USER *
C *
C XEND VALUE OF X TO WHICH INTEGRATION IS TO BE CARRIED OUT - IT MAY *
C BE LESS THAN THE INITIAL VALUE OF X *
C *
C TOL TOLERANCE - THE SUBROUTINE ATTEMPTS TO CONTROL A NORM OF THE *
C LOCAL ERROR IN SUCH A WAY THAT THE GLOBAL ERROR IS *
C PROPORTIONAL TO TOL. IN SOME PROBLEMS THERE WILL BE ENOUGH *
C DAMPING OF ERRORS, AS WELL AS SOME CANCELLATION, SO THAT *
C THE GLOBAL ERROR WILL BE LESS THAN TOL. ALTERNATIVELY, THE *
C CONTROL CAN BE VIEWED AS ATTEMPTING TO PROVIDE A *
C CALCULATED VALUE OF Y AT XEND WHICH IS THE EXACT SOLUTION *
C TO THE PROBLEM Y' = F(X,Y) + E(X) WHERE THE NORM OF E(X) *
C IS PROPORTIONAL TO TOL. (THE NORM IS A MAX NORM WITH *
C WEIGHTS THAT DEPEND ON THE ERROR CONTROL STRATEGY CHOSEN *
C BY THE USER. THE DEFAULT WEIGHT FOR THE K-TH COMPONENT IS *
C 1/MAX(1,ABS(Y(K))), WHICH THEREFORE PROVIDES A MIXTURE OF *
C ABSOLUTE AND RELATIVE ERROR CONTROL.) *
C *
C IND INDICATOR - ON INITIAL ENTRY IND MUST BE SET EQUAL TO EITHER *
C 1 OR 2. IF THE USER DOES NOT WISH TO USE ANY OPTIONS, HE *
C SHOULD SET IND TO 1 - ALL THAT REMAINS FOR THE USER TO DO *
C THEN IS TO DECLARE C AND W, AND TO SPECIFY NW. THE USER *
C MAY ALSO SELECT VARIOUS OPTIONS ON INITIAL ENTRY BY *
C SETTING IND = 2 AND INITIALIZING THE FIRST 9 COMPONENTS OF *
C C AS DESCRIBED IN THE NEXT SECTION. HE MAY ALSO RE-ENTER *
C THE SUBROUTINE WITH IND = 3 AS MENTIONED AGAIN BELOW. IN *
C ANY EVENT, THE SUBROUTINE RETURNS WITH IND EQUAL TO *
C 3 AFTER A NORMAL RETURN *
C 4, 5, OR 6 AFTER AN INTERRUPT (SEE OPTIONS C(8), C(9)) *
C -1, -2, OR -3 AFTER AN ERROR CONDITION (SEE BELOW) *
C *
C C COMMUNICATIONS VECTOR - THE DIMENSION MUST BE GREATER THAN OR *
C EQUAL TO 24, UNLESS OPTION C(1) = 4 OR 5 IS USED, IN WHICH *
C CASE THE DIMENSION MUST BE GREATER THAN OR EQUAL TO N+30 *
C *
C NW FIRST DIMENSION OF WORKSPACE W - MUST BE GREATER THAN OR *
C EQUAL TO N *
C *
C W WORKSPACE MATRIX - FIRST DIMENSION MUST BE NW AND SECOND MUST *
C BE GREATER THAN OR EQUAL TO 9 *
C *
C THE SUBROUTINE WILL NORMALLY RETURN WITH IND = 3, HAVING *
C REPLACED THE INITIAL VALUES OF X AND Y WITH, RESPECTIVELY, THE VALUE *
C OF XEND AND AN APPROXIMATION TO Y AT XEND. THE SUBROUTINE CAN BE *
C CALLED REPEATEDLY WITH NEW VALUES OF XEND WITHOUT HAVING TO CHANGE *
C ANY OTHER ARGUMENT. HOWEVER, CHANGES IN TOL, OR ANY OF THE OPTIONS *
C DESCRIBED BELOW, MAY ALSO BE MADE ON SUCH A RE-ENTRY IF DESIRED. *
C *
C THREE ERROR RETURNS ARE ALSO POSSIBLE, IN WHICH CASE X AND Y *
C WILL BE THE MOST RECENTLY ACCEPTED VALUES - *
C WITH IND = -3 THE SUBROUTINE WAS UNABLE TO SATISFY THE ERROR *
C REQUIREMENT WITH A PARTICULAR STEP-SIZE THAT IS LESS THAN OR *
C EQUAL TO HMIN, WHICH MAY MEAN THAT TOL IS TOO SMALL *
C WITH IND = -2 THE VALUE OF HMIN IS GREATER THAN HMAX, WHICH *
C PROBABLY MEANS THAT THE REQUESTED TOL (WHICH IS USED IN THE *
C CALCULATION OF HMIN) IS TOO SMALL *
C WITH IND = -1 THE ALLOWED MAXIMUM NUMBER OF FCN EVALUATIONS HAS *
C BEEN EXCEEDED, BUT THIS CAN ONLY OCCUR IF OPTION C(7), AS *
C DESCRIBED IN THE NEXT SECTION, HAS BEEN USED *
C *
C THERE ARE SEVERAL CIRCUMSTANCES THAT WILL CAUSE THE CALCULATIONS *
C TO BE TERMINATED, ALONG WITH OUTPUT OF INFORMATION THAT WILL HELP *
C THE USER DETERMINE THE CAUSE OF THE TROUBLE. THESE CIRCUMSTANCES *
C INVOLVE ENTRY WITH ILLEGAL OR INCONSISTENT VALUES OF THE ARGUMENTS, *
C SUCH AS ATTEMPTING A NORMAL RE-ENTRY WITHOUT FIRST CHANGING THE *
C VALUE OF XEND, OR ATTEMPTING TO RE-ENTER WITH IND LESS THAN ZERO. *
C *
C *
C OPTIONS - IF THE SUBROUTINE IS ENTERED WITH IND = 1, THE FIRST 9 *
C COMPONENTS OF THE COMMUNICATIONS VECTOR ARE INITIALIZED TO ZERO, AND *
C THE SUBROUTINE USES ONLY DEFAULT VALUES FOR EACH OPTION. IF THE *
C SUBROUTINE IS ENTERED WITH IND = 2, THE USER MUST SPECIFY EACH OF *
C THESE 9 COMPONENTS - NORMALLY HE WOULD FIRST SET THEM ALL TO ZERO, *
C AND THEN MAKE NON-ZERO THOSE THAT CORRESPOND TO THE PARTICULAR *
C OPTIONS HE WISHES TO SELECT. IN ANY EVENT, OPTIONS MAY BE CHANGED ON *
C RE-ENTRY TO THE SUBROUTINE - BUT IF THE USER CHANGES ANY OF THE *
C OPTIONS, OR TOL, IN THE COURSE OF A CALCULATION HE SHOULD BE CAREFUL *
C ABOUT HOW SUCH CHANGES AFFECT THE SUBROUTINE - IT MAY BE BETTER TO *
C RESTART WITH IND = 1 OR 2. (COMPONENTS 10 TO 24 OF C ARE USED BY THE *
C PROGRAM - THE INFORMATION IS AVAILABLE TO THE USER, BUT SHOULD NOT *
C NORMALLY BE CHANGED BY HIM.) *
C *
C C(1) ERROR CONTROL INDICATOR - THE NORM OF THE LOCAL ERROR IS THE *
C MAX NORM OF THE WEIGHTED ERROR ESTIMATE VECTOR, THE *
C WEIGHTS BEING DETERMINED ACCORDING TO THE VALUE OF C(1) - *
C IF C(1)=1 THE WEIGHTS ARE 1 (ABSOLUTE ERROR CONTROL) *
C IF C(1)=2 THE WEIGHTS ARE 1/ABS(Y(K)) (RELATIVE ERROR *
C CONTROL) *
C IF C(1)=3 THE WEIGHTS ARE 1/MAX(ABS(C(2)),ABS(Y(K))) *
C (RELATIVE ERROR CONTROL, UNLESS ABS(Y(K)) IS LESS *
C THAN THE FLOOR VALUE, ABS(C(2)) ) *
C IF C(1)=4 THE WEIGHTS ARE 1/MAX(ABS(C(K+30)),ABS(Y(K))) *
C (HERE INDIVIDUAL FLOOR VALUES ARE USED) *
C IF C(1)=5 THE WEIGHTS ARE 1/ABS(C(K+30)) *
C FOR ALL OTHER VALUES OF C(1), INCLUDING C(1) = 0, THE *
C DEFAULT VALUES OF THE WEIGHTS ARE TAKEN TO BE *
C 1/MAX(1,ABS(Y(K))), AS MENTIONED EARLIER *
C (IN THE TWO CASES C(1) = 4 OR 5 THE USER MUST DECLARE THE *
C DIMENSION OF C TO BE AT LEAST N+30 AND MUST INITIALIZE THE *
C COMPONENTS C(31), C(32), ..., C(N+30).) *
C *
C C(2) FLOOR VALUE - USED WHEN THE INDICATOR C(1) HAS THE VALUE 3 *
C *
C C(3) HMIN SPECIFICATION - IF NOT ZERO, THE SUBROUTINE CHOOSES HMIN *
C TO BE ABS(C(3)) - OTHERWISE IT USES THE DEFAULT VALUE *
C 10*MAX(DWARF,RREB*MAX(WEIGHTED NORM Y/TOL,ABS(X))), *
C WHERE DWARF IS A VERY SMALL POSITIVE MACHINE NUMBER AND *
C RREB IS THE RELATIVE ROUNDOFF ERROR BOUND *
C *
C C(4) HSTART SPECIFICATION - IF NOT ZERO, THE SUBROUTINE WILL USE *
C AN INITIAL HMAG EQUAL TO ABS(C(4)), EXCEPT OF COURSE FOR *
C THE RESTRICTIONS IMPOSED BY HMIN AND HMAX - OTHERWISE IT *
C USES THE DEFAULT VALUE OF HMAX*(TOL)**(1/6) *
C *
C C(5) SCALE SPECIFICATION - THIS IS INTENDED TO BE A MEASURE OF THE *
C SCALE OF THE PROBLEM - LARGER VALUES OF SCALE TEND TO MAKE *
C THE METHOD MORE RELIABLE, FIRST BY POSSIBLY RESTRICTING *
C HMAX (AS DESCRIBED BELOW) AND SECOND, BY TIGHTENING THE *
C ACCEPTANCE REQUIREMENT - IF C(5) IS ZERO, A DEFAULT VALUE *
C OF 1 IS USED. FOR LINEAR HOMOGENEOUS PROBLEMS WITH *
C CONSTANT COEFFICIENTS, AN APPROPRIATE VALUE FOR SCALE IS A *
C NORM OF THE ASSOCIATED MATRIX. FOR OTHER PROBLEMS, AN *
C APPROXIMATION TO AN AVERAGE VALUE OF A NORM OF THE *
C JACOBIAN ALONG THE TRAJECTORY MAY BE APPROPRIATE *
C *
C C(6) HMAX SPECIFICATION - FOUR CASES ARE POSSIBLE *
C IF C(6).NE.0 AND C(5).NE.0, HMAX IS TAKEN TO BE *
C MIN(ABS(C(6)),2/ABS(C(5))) *
C IF C(6).NE.0 AND C(5).EQ.0, HMAX IS TAKEN TO BE ABS(C(6)) *
C IF C(6).EQ.0 AND C(5).NE.0, HMAX IS TAKEN TO BE *
C 2/ABS(C(5)) *
C IF C(6).EQ.0 AND C(5).EQ.0, HMAX IS GIVEN A DEFAULT VALUE *
C OF 2 *
C *
C C(7) MAXIMUM NUMBER OF FUNCTION EVALUATIONS - IF NOT ZERO, AN *
C ERROR RETURN WITH IND = -1 WILL BE CAUSED WHEN THE NUMBER *
C OF FUNCTION EVALUATIONS EXCEEDS ABS(C(7)) *
C *
C C(8) INTERRUPT NUMBER 1 - IF NOT ZERO, THE SUBROUTINE WILL *
C INTERRUPT THE CALCULATIONS AFTER IT HAS CHOSEN ITS *
C PRELIMINARY VALUE OF HMAG, AND JUST BEFORE CHOOSING HTRIAL *
C AND XTRIAL IN PREPARATION FOR TAKING A STEP (HTRIAL MAY *
C DIFFER FROM HMAG IN SIGN, AND MAY REQUIRE ADJUSTMENT IF *
C XEND IS NEAR) - THE SUBROUTINE RETURNS WITH IND = 4, AND *
C WILL RESUME CALCULATION AT THE POINT OF INTERRUPTION IF *
C RE-ENTERED WITH IND = 4 *
C *
C C(9) INTERRUPT NUMBER 2 - IF NOT ZERO, THE SUBROUTINE WILL *
C INTERRUPT THE CALCULATIONS IMMEDIATELY AFTER IT HAS *
C DECIDED WHETHER OR NOT TO ACCEPT THE RESULT OF THE MOST *
C RECENT TRIAL STEP, WITH IND = 5 IF IT PLANS TO ACCEPT, OR *
C IND = 6 IF IT PLANS TO REJECT - Y(*) IS THE PREVIOUSLY *
C ACCEPTED RESULT, WHILE W(*,9) IS THE NEWLY COMPUTED TRIAL *
C VALUE, AND W(*,2) IS THE UNWEIGHTED ERROR ESTIMATE VECTOR. *
C THE SUBROUTINE WILL RESUME CALCULATIONS AT THE POINT OF *
C INTERRUPTION ON RE-ENTRY WITH IND = 5 OR 6. (THE USER MAY *
C CHANGE IND IN THIS CASE IF HE WISHES, FOR EXAMPLE TO FORCE *
C ACCEPTANCE OF A STEP THAT WOULD OTHERWISE BE REJECTED, OR *
C VICE VERSA. HE CAN ALSO RESTART WITH IND = 1 OR 2.) *
C *
C *
C SUMMARY OF THE COMPONENTS OF THE COMMUNICATIONS VECTOR *
C *
C PRESCRIBED AT THE OPTION DETERMINED BY THE PROGRAM *
C OF THE USER *
C *
C C(10) RREB(REL ROUNDOFF ERR BND) *
C C(1) ERROR CONTROL INDICATOR C(11) DWARF (VERY SMALL MACH NO) *
C C(2) FLOOR VALUE C(12) WEIGHTED NORM Y *
C C(3) HMIN SPECIFICATION C(13) HMIN *
C C(4) HSTART SPECIFICATION C(14) HMAG *
C C(5) SCALE SPECIFICATION C(15) SCALE *
C C(6) HMAX SPECIFICATION C(16) HMAX *
C C(7) MAX NO OF FCN EVALS C(17) XTRIAL *
C C(8) INTERRUPT NO 1 C(18) HTRIAL *
C C(9) INTERRUPT NO 2 C(19) EST *
C C(20) PREVIOUS XEND *
C C(21) FLAG FOR XEND *
C C(22) NO OF SUCCESSFUL STEPS *
C C(23) NO OF SUCCESSIVE FAILURES *
C C(24) NO OF FCN EVALS *
C *
C IF C(1) = 4 OR 5, C(31), C(32), ... C(N+30) ARE FLOOR VALUES *
C *
C RREB and DWARF are machine dependent constants currently set so *
C that they should be appropriate for most machines. However, it may *
C be appropriate to change them when this program is installed on a *
C new machine. K.R.J. 3 Oct 1991. *
C *
C *
C AN OVERVIEW OF THE PROGRAM *
C *
C BEGIN INITIALIZATION, PARAMETER CHECKING, INTERRUPT RE-ENTRIES *
C ......ABORT IF IND OUT OF RANGE 1 TO 6 *
C . CASES - INITIAL ENTRY, NORMAL RE-ENTRY, INTERRUPT RE-ENTRIES *
C . CASE 1 - INITIAL ENTRY (IND .EQ. 1 OR 2) *
C V........ABORT IF N.GT.NW OR TOL.LE.0 *
C . IF INITIAL ENTRY WITHOUT OPTIONS (IND .EQ. 1) *
C . SET C(1) TO C(9) EQUAL TO ZERO *
C . ELSE INITIAL ENTRY WITH OPTIONS (IND .EQ. 2) *
C . MAKE C(1) TO C(9) NON-NEGATIVE *
C . MAKE FLOOR VALUES NON-NEGATIVE IF THEY ARE TO BE USED *
C . END IF *
C . INITIALIZE RREB, DWARF, PREV XEND, FLAG, COUNTS *
C . CASE 2 - NORMAL RE-ENTRY (IND .EQ. 3) *
C .........ABORT IF XEND REACHED, AND EITHER X CHANGED OR XEND NOT *
C . RE-INITIALIZE FLAG *
C . CASE 3 - RE-ENTRY FOLLOWING AN INTERRUPT (IND .EQ. 4 TO 6) *
C V TRANSFER CONTROL TO THE APPROPRIATE RE-ENTRY POINT....... *
C . END CASES . *
C . END INITIALIZATION, ETC. . *
C . V *
C . LOOP THROUGH THE FOLLOWING 4 STAGES, ONCE FOR EACH TRIAL STEP . *
C . STAGE 1 - PREPARE . *
C***********ERROR RETURN (WITH IND=-1) IF NO OF FCN EVALS TOO GREAT . *
C . CALC SLOPE (ADDING 1 TO NO OF FCN EVALS) IF IND .NE. 6 . *
C . CALC HMIN, SCALE, HMAX . *
C***********ERROR RETURN (WITH IND=-2) IF HMIN .GT. HMAX . *
C . CALC PRELIMINARY HMAG . *
C***********INTERRUPT NO 1 (WITH IND=4) IF REQUESTED.......RE-ENTRY.V *
C . CALC HMAG, XTRIAL AND HTRIAL . *
C . END STAGE 1 . *
C V STAGE 2 - CALC YTRIAL (ADDING 7 TO NO OF FCN EVALS) . *
C . STAGE 3 - CALC THE ERROR ESTIMATE . *
C . STAGE 4 - MAKE DECISIONS . *
C . SET IND=5 IF STEP ACCEPTABLE, ELSE SET IND=6 . *
C***********INTERRUPT NO 2 IF REQUESTED....................RE-ENTRY.V *
C . IF STEP ACCEPTED (IND .EQ. 5) *
C . UPDATE X, Y FROM XTRIAL, YTRIAL *
C . ADD 1 TO NO OF SUCCESSFUL STEPS *
C . SET NO OF SUCCESSIVE FAILURES TO ZERO *
C**************RETURN(WITH IND=3, XEND SAVED, FLAG SET) IF X .EQ. XEND *
C . ELSE STEP NOT ACCEPTED (IND .EQ. 6) *
C . ADD 1 TO NO OF SUCCESSIVE FAILURES *
C**************ERROR RETURN (WITH IND=-3) IF HMAG .LE. HMIN *
C . END IF *
C . END STAGE 4 *
C . END LOOP *
C . *
C BEGIN ABORT ACTION *
C OUTPUT APPROPRIATE MESSAGE ABOUT STOPPING THE CALCULATIONS, *
C ALONG WITH VALUES OF IND, N, NW, TOL, HMIN, HMAX, X, XEND, *
C PREVIOUS XEND, NO OF SUCCESSFUL STEPS, NO OF SUCCESSIVE *
C FAILURES, NO OF FCN EVALS, AND THE COMPONENTS OF Y *
C STOP *
C END ABORT ACTION *
C *
C
C ******************************************************************
C * BEGIN INITIALIZATION, PARAMETER CHECKING, INTERRUPT RE-ENTRIES *
C
IF (IND.LT.1 .OR. IND.GT.6) GO TO 500
C
C CASES - INITIAL ENTRY, NORMAL RE-ENTRY, INTERRUPT RE-ENTRIES
GO TO (5, 5, 45, 1111, 2222, 2222), IND
C CASE 1 - INITIAL ENTRY (IND .EQ. 1 OR 2)
C .........ABORT IF N.GT.NW OR TOL.LE.0
5 IF (N.GT.NW .OR. TOL.LE.0.D0) GO TO 500
IF (IND.EQ. 2) GO TO 15
C INITIAL ENTRY WITHOUT OPTIONS (IND .EQ. 1)
C SET C(1) TO C(9) EQUAL TO 0
DO 10 K = 1, 9
C(K) = 0.D0
10 CONTINUE
GO TO 35
15 CONTINUE
C INITIAL ENTRY WITH OPTIONS (IND .EQ. 2)
C MAKE C(1) TO C(9) NON-NEGATIVE
DO 20 K = 1, 9
C(K) = DABS(C(K))
20 CONTINUE
C MAKE FLOOR VALUES NON-NEGATIVE IF THEY ARE TO BE USED
IF (C(1).NE.4.D0 .AND. C(1).NE.5.D0) GO TO 30
DO 25 K = 1, N
C(K+30) = DABS(C(K+30))
25 CONTINUE
30 CONTINUE
35 CONTINUE
C INITIALIZE RREB, DWARF, PREV XEND, FLAG, COUNTS
C(10) = 2.D0**(-56)
C(11) = 1.D-35
C SET PREVIOUS XEND INITIALLY TO INITIAL VALUE OF X
C(20) = X
DO 40 K = 21, 24
C(K) = 0.D0
40 CONTINUE
GO TO 50
C CASE 2 - NORMAL RE-ENTRY (IND .EQ. 3)
45 IF (C(21).NE.0.D0 .AND.
+ (X.NE.C(20) .OR. XEND.EQ.C(20))) GO TO 500
C RE-INITIALIZE FLAG
C(21) = 0.D0
GO TO 50
C CASE 3 - RE-ENTRY FOLLOWING AN INTERRUPT (IND .EQ. 4 TO 6)
C TRANSFER CONTROL TO THE APPROPRIATE RE-ENTRY POINT..........
C THIS HAS ALREADY BEEN HANDLED BY THE COMPUTED GO TO .
C END CASES V
50 CONTINUE
C
C END INITIALIZATION, ETC.
C
C * LOOP THROUGH THE FOLLOWING 4 STAGES, ONCE FOR EACH TRIAL STEP *
C * UNTIL THE OCCURRENCE OF ONE OF THE FOLLOWING *
C * (A) THE NORMAL RETURN (WITH IND .EQ. 3) ON REACHING XEND IN *
C * STAGE 4 *
C * (B) AN ERROR RETURN (WITH IND .LT. 0) IN STAGE 1 OR STAGE 4 *
C * (C) AN INTERRUPT RETURN (WITH IND .EQ. 4, 5 OR 6), IF *
C * REQUESTED, IN STAGE 1 OR STAGE 4 *
C
99999 CONTINUE
C
C * STAGE 1 - PREPARE - DO CALCULATIONS OF HMIN, HMAX, ETC., *
C * AND SOME PARAMETER CHECKING, AND END UP WITH SUITABLE *
C * VALUES OF HMAG, XTRIAL AND HTRIAL IN PREPARATION FOR TAKING *
C * AN INTEGRATION STEP. *
C
IF (C(7).EQ.0.D0 .OR. C(24).LT.C(7)) GO TO 100
IND = -1
RETURN
100 CONTINUE
C
C CALCULATE SLOPE (ADDING 1 TO NO OF FCN EVALS) IF IND .NE. 6
IF (IND .EQ. 6) GO TO 105
CALL FCN(N, X, Y, W(1,1))
C(24) = C(24) + 1.D0
105 CONTINUE
C
C CALCULATE HMIN - USE DEFAULT UNLESS VALUE PRESCRIBED
C(13) = C(3)
IF (C(3) .NE. 0.D0) GO TO 165
C CALCULATE DEFAULT VALUE OF HMIN
C FIRST CALCULATE WEIGHTED NORM Y - C(12) - AS SPECIFIED
C BY THE ERROR CONTROL INDICATOR C(1)
TEMP = 0.D0
IF (C(1) .NE. 1.D0) GO TO 115
C ABSOLUTE ERROR CONTROL - WEIGHTS ARE 1
DO 110 K = 1, N
TEMP = DMAX1(TEMP, DABS(Y(K)))
110 CONTINUE
C(12) = TEMP
GO TO 160
115 IF (C(1) .NE. 2.D0) GO TO 120
C RELATIVE ERROR CONTROL - WEIGHTS ARE 1/DABS(Y(K)) SO
C WEIGHTED NORM Y IS 1
C(12) = 1.D0
GO TO 160
120 IF (C(1) .NE. 3.D0) GO TO 130
C WEIGHTS ARE 1/MAX(C(2),ABS(Y(K)))
DO 125 K = 1, N
TEMP = DMAX1(TEMP, DABS(Y(K))/C(2))
125 CONTINUE
C(12) = DMIN1(TEMP, 1.D0)
GO TO 160
130 IF (C(1) .NE. 4.D0) GO TO 140
C WEIGHTS ARE 1/MAX(C(K+30),ABS(Y(K)))
DO 135 K = 1, N
TEMP = DMAX1(TEMP, DABS(Y(K))/C(K+30))
135 CONTINUE
GO TO 160
140 IF (C(1) .NE. 5.D0) GO TO 150
C WEIGHTS ARE 1/C(K+30)
DO 145 K = 1, N
145 CONTINUE
C(12) = TEMP
GO TO 160
150 CONTINUE
C DEFAULT CASE - WEIGHTS ARE 1/MAX(1,ABS(Y(K)))
DO 155 K = 1, N
155 CONTINUE
160 CONTINUE
C(13) = 10.D0*DMAX1(C(11),C(10)*DMAX1(C(12)/TOL,DABS(X)))
165 CONTINUE
C
C CALCULATE SCALE - USE DEFAULT UNLESS VALUE PRESCRIBED
C(15) = C(5)
IF (C(5) .EQ. 0.D0) C(15) = 1.D0
C
C CALCULATE HMAX - CONSIDER 4 CASES
C CASE 1 BOTH HMAX AND SCALE PRESCRIBED
IF (C(6).NE.0.D0 .AND. C(5).NE.0.D0)
+ C(16) = DMIN1(C(6), 2.D0/C(5))
C CASE 2 - HMAX PRESCRIBED, BUT SCALE NOT
IF (C(6).NE.0.D0 .AND. C(5).EQ.0.D0) C(16) = C(6)
C CASE 3 - HMAX NOT PRESCRIBED, BUT SCALE IS
IF (C(6).EQ.0.D0 .AND. C(5).NE.0.D0) C(16) = 2.D0/C(5)
C CASE 4 - NEITHER HMAX NOR SCALE IS PROVIDED
IF (C(6).EQ.0.D0 .AND. C(5).EQ.0.D0) C(16) = 2.D0
C
IF (C(13) .LE. C(16)) GO TO 170
IND = -2
RETURN
170 CONTINUE
C
C CALCULATE PRELIMINARY HMAG - CONSIDER 3 CASES
IF (IND .GT. 2) GO TO 175
C CASE 1 - INITIAL ENTRY - USE PRESCRIBED VALUE OF HSTART, IF
C ANY, ELSE DEFAULT
C(14) = C(4)
IF (C(4) .EQ. 0.D0) C(14) = C(16)*TOL**(1./6.)
GO TO 185
175 IF (C(23) .GT. 1.D0) GO TO 180
C CASE 2 - AFTER A SUCCESSFUL STEP, OR AT MOST ONE FAILURE,
C USE MIN(2, .9*(TOL/EST)**(1/6))*HMAG, BUT AVOID POSSIBLE
C OVERFLOW. THEN AVOID REDUCTION BY MORE THAN HALF.
TEMP = 2.D0*C(14)
IF (TOL .LT. (2.D0/.9D0)**6*C(19))
+ TEMP = .9D0*(TOL/C(19))**(1./6.)*C(14)
C(14) = DMAX1(TEMP, .5D0*C(14))
GO TO 185
180 CONTINUE
C CASE 3 - AFTER TWO OR MORE SUCCESSIVE FAILURES
C(14) = .5D0*C(14)
185 CONTINUE
C
C CHECK AGAINST HMAX
C(14) = DMIN1(C(14), C(16))
C
C CHECK AGAINST HMIN
C(14) = DMAX1(C(14), C(13))
C
IF (C(8) .EQ. 0.D0) GO TO 1111
IND = 4
RETURN
C RESUME HERE ON RE-ENTRY WITH IND .EQ. 4 ........RE-ENTRY..
1111 CONTINUE
C
C CALCULATE HMAG, XTRIAL - DEPENDING ON PRELIMINARY HMAG, XEND
IF (C(14) .GE. DABS(XEND - X)) GO TO 190
C DO NOT STEP MORE THAN HALF WAY TO XEND
C(14) = DMIN1(C(14), .5D0*DABS(XEND - X))
C(17) = X + DSIGN(C(14), XEND - X)
GO TO 195
190 CONTINUE
C HIT XEND EXACTLY
C(14) = DABS(XEND - X)
C(17) = XEND
195 CONTINUE
C
C CALCULATE HTRIAL
C(18) = C(17) - X
C
C END STAGE 1
C
C * STAGE 2 - CALCULATE YTRIAL (ADDING 7 TO NO OF FCN EVALS). *
C * W(*,2), ... W(*,8) HOLD INTERMEDIATE RESULTS NEEDED IN *
C * STAGE 3. W(*,9) IS TEMPORARY STORAGE UNTIL FINALLY IT HOLDS *
C * YTRIAL. *
C
TEMP = C(18)/1398169080000.D0
C
DO 200 K = 1, N
W(K,9) = Y(K) + TEMP*W(K,1)*233028180000.D0
200 CONTINUE
CALL FCN(N, X + C(18)/6.D0, W(1,9), W(1,2))
C
DO 205 K = 1, N
W(K,9) = Y(K) + TEMP*( W(K,1)*74569017600.D0
+ + W(K,2)*298276070400.D0 )
205 CONTINUE
CALL FCN(N, X + C(18)*(4.D0/15.D0), W(1,9), W(1,3))
C
DO 210 K = 1, N
W(K,9) = Y(K) + TEMP*( W(K,1)*1165140900000.D0
+ - W(K,2)*3728450880000.D0
+ + W(K,3)*3495422700000.D0 )
210 CONTINUE
CALL FCN(N, X + C(18)*(2.D0/3.D0), W(1,9), W(1,4))
C
DO 215 K = 1, N
W(K,9) = Y(K) + TEMP*( - W(K,1)*3604654659375.D0
+ + W(K,2)*12816549900000.D0
+ - W(K,3)*9284716546875.D0
+ + W(K,4)*1237962206250.D0 )
215 CONTINUE
CALL FCN(N, X + C(18)*(5.D0/6.D0), W(1,9), W(1,5))
C
DO 220 K = 1, N
W(K,9) = Y(K) + TEMP*( W(K,1)*3355605792000.D0
+ - W(K,2)*11185352640000.D0
+ + W(K,3)*9172628850000.D0
+ - W(K,4)*427218330000.D0
+ + W(K,5)*482505408000.D0 )
220 CONTINUE
CALL FCN(N, X + C(18), W(1,9), W(1,6))
C
DO 225 K = 1, N
W(K,9) = Y(K) + TEMP*( - W(K,1)*770204740536.D0
+ + W(K,2)*2311639545600.D0
+ - W(K,3)*1322092233000.D0
+ - W(K,4)*453006781920.D0
+ + W(K,5)*326875481856.D0 )
225 CONTINUE
CALL FCN(N, X + C(18)/15.D0, W(1,9), W(1,7))
C
DO 230 K = 1, N
W(K,9) = Y(K) + TEMP*( W(K,1)*2845924389000.D0
+ - W(K,2)*9754668000000.D0
+ + W(K,3)*7897110375000.D0
+ - W(K,4)*192082660000.D0
+ + W(K,5)*400298976000.D0
+ + W(K,7)*201586000000.D0 )
230 CONTINUE
CALL FCN(N, X + C(18), W(1,9), W(1,8))
C
C CALCULATE YTRIAL, THE EXTRAPOLATED APPROXIMATION AND STORE
C IN W(*,9)
DO 235 K = 1, N
W(K,9) = Y(K) + TEMP*( W(K,1)*104862681000.D0
+ + W(K,3)*545186250000.D0
+ + W(K,4)*446637345000.D0
+ + W(K,5)*188806464000.D0
+ + W(K,7)*15076875000.D0
+ + W(K,8)*97599465000.D0 )
235 CONTINUE
C
C ADD 7 TO THE NO OF FCN EVALS
C(24) = C(24) + 7.D0
C
C END STAGE 2
C
C * STAGE 3 - CALCULATE THE ERROR ESTIMATE EST. FIRST CALCULATE *
C * THE UNWEIGHTED ABSOLUTE ERROR ESTIMATE VECTOR (PER UNIT *
C * STEP) FOR THE UNEXTRAPOLATED APPROXIMATION AND STORE IT IN *
C * W(*,2). THEN CALCULATE THE WEIGHTED MAX NORM OF W(*,2) AS *
C * SPECIFIED BY THE ERROR CONTROL INDICATOR C(1). FINALLY, *
C * MODIFY THIS RESULT TO PRODUCE EST, THE ERROR ESTIMATE (PER *
C * UNIT STEP) FOR THE EXTRAPOLATED APPROXIMATION YTRIAL. *
C
C CALCULATE THE UNWEIGHTED ABSOLUTE ERROR ESTIMATE VECTOR
DO 300 K = 1, N
W(K,2) = ( W(K,1)*8738556750.D0
+ + W(K,3)*9735468750.D0
+ - W(K,4)*9709507500.D0
+ + W(K,5)*8582112000.D0
+ + W(K,6)*95329710000.D0
+ - W(K,7)*15076875000.D0
+ - W(K,8)*97599465000.D0)/1398169080000.D0
300 CONTINUE
C
C CALCULATE THE WEIGHTED MAX NORM OF W(*,2) AS SPECIFIED BY
C THE ERROR CONTROL INDICATOR C(1)
TEMP = 0.D0
IF (C(1) .NE. 1.D0) GO TO 310
DO 305 K = 1, N
TEMP = DMAX1(TEMP,DABS(W(K,2)))
305 CONTINUE
GO TO 360
310 IF (C(1) .NE. 2.D0) GO TO 320
DO 315 K = 1, N
TEMP = DMAX1(TEMP, DABS(W(K,2)/Y(K)))
315 CONTINUE
GO TO 360
320 IF (C(1) .NE. 3.D0) GO TO 330
DO 325 K = 1, N
TEMP = DMAX1(TEMP, DABS(W(K,2))
+ / DMAX1(C(2), DABS(Y(K))) )
325 CONTINUE
GO TO 360
330 IF (C(1) .NE. 4.D0) GO TO 340
DO 335 K = 1, N
+ / DMAX1(C(K+30), DABS(Y(K))) )
335 CONTINUE
GO TO 360
340 IF (C(1) .NE. 5.D0) GO TO 350
DO 345 K = 1, N
TEMP = DMAX1(TEMP, DABS(W(K,2)/C(K+30)))
345 CONTINUE
GO TO 360
350 CONTINUE
DO 355 K = 1, N
+ / DMAX1(1.D0, DABS(Y(K))) )
355 CONTINUE
360 CONTINUE
C
C CALCULATE EST - (THE WEIGHTED MAX NORM OF W(*,2))*HMAG*SCALE
C - EST IS INTENDED TO BE A MEASURE OF THE ERROR PER UNIT
C STEP IN YTRIAL
C(19) = TEMP*C(14)*C(15)
C
C END STAGE 3
C
C * STAGE 4 - MAKE DECISIONS. *
C
C SET IND=5 IF STEP ACCEPTABLE, ELSE SET IND=6
IND = 5
IF (C(19) .GT. TOL) IND = 6
C
IF (C(9) .EQ. 0.D0) GO TO 2222
RETURN
C RESUME HERE ON RE-ENTRY WITH IND .EQ. 5 OR 6 ...RE-ENTRY..
2222 CONTINUE
C
IF (IND .EQ. 6) GO TO 410
C STEP ACCEPTED (IND .EQ. 5), SO UPDATE X, Y FROM XTRIAL,
C YTRIAL, ADD 1 TO THE NO OF SUCCESSFUL STEPS, AND SET
C THE NO OF SUCCESSIVE FAILURES TO ZERO
X = C(17)
DO 400 K = 1, N
Y(K) = W(K,9)
400 CONTINUE
C(22) = C(22) + 1.D0
C(23) = 0.D0
IF (X .NE. XEND) GO TO 405
IND = 3
C(20) = XEND
C(21) = 1.D0
RETURN
405 CONTINUE
GO TO 420
410 CONTINUE
C STEP NOT ACCEPTED (IND .EQ. 6), SO ADD 1 TO THE NO OF
C SUCCESSIVE FAILURES
C(23) = C(23) + 1.D0
IF (C(14) .GT. C(13)) GO TO 415
IND = -3
RETURN
415 CONTINUE
420 CONTINUE
C
C END STAGE 4
C
GO TO 99999
C END LOOP
C
500 CONTINUE
C
WRITE(6,505) IND, TOL, X, N, C(13), XEND, NW, C(16), C(20),
+ C(22), C(23), C(24), (Y(K), K = 1, N)
505 FORMAT( /// 1H0, 58HCOMPUTATION STOPPED IN DVERK WITH THE FOLLOWIN
+ G VALUES-
+ / 1H0, 5HIND =, I4, 5X, 6HTOL =, 1PD13.6, 5X, 11HX =,
+ 1PD22.15
+ / 1H , 5HN =, I4, 5X, 6HHMIN =, 1PD13.6, 5X, 11HXEND =,
+ 1PD22.15
+ / 1H , 5HNW =, I4, 5X, 6HHMAX =, 1PD13.6, 5X, 11HPREV XEND =,
+ 1PD22.15
+ / 1H0, 14X, 27HNO OF SUCCESSFUL STEPS =, 0PF8.0
+ / 1H , 14X, 27HNO OF SUCCESSIVE FAILURES =, 0PF8.0
+ / 1H , 14X, 27HNO OF FUNCTION EVALS =, 0PF8.0
+ / 1H0, 23HTHE COMPONENTS OF Y ARE
+ // (1H , 1P5D24.15) )
C
STOP
C
C END ABORT ACTION
C
END
C
C
subroutine fcn(neq, t, y, yprime)
implicit none
c-----------------------------------------------------------------------
c
include 'fcn.inc'
c Arguments of subroutine and indices
c Note: dimension of y is nst*(nst+3) (nst = dims(4))
c dimension of yprime is neq = dims(1)
integer ic, jc
integer minst, maxst, nst
real*8 t
integer neq
real*8 y, yprime,TOTIME,HBAR, V,W,TOCYC,THETA
dimension neq(4)
dimension y(1), yprime(1)
c Temporaries for dimension of system
minst = neq(2)
maxst = neq(3)
nst = neq(4)
c Define derivatives
c Note: y(ic) = a(ic+maxst-nst)
c y(ic+nst) = b(ic+maxst-nst)
c y(ic+2*nst) = E(ic+maxst-nst)
c y(nst*ic+jc+2*nst) = x(jc+maxst-nst,ic+maxst-nst)
c
c Note: we will replace x(j,i) with x(i,j) in the calculations
c below for better vectorization. We can do this as long as
c the x(j,i) are real.
if (t .lt. totime) then
do ic = 1, nst
yprime(ic) = y(ic+2*nst)*y(ic+nst)/hbar
yprime(ic+nst) = - y(ic+2*nst)*y(ic)/hbar
do jc = 1, nst
yprime(ic) = yprime(ic) -
& V*(sin(w*t/(4.0d0*tocyc))**2)*
& cos(w*t+theta)*
& y(nst*ic+jc+2*nst)*y(jc+nst)/hbar
yprime(ic+nst) = yprime(ic+nst)
& +V*(sin(w*t/(4.0d0*tocyc))**2)*
& cos(w*t+theta)*
& y(nst*ic+jc+2*nst)*y(jc)/hbar
end do
end do
else
do ic = 1, nst
do jc = 1, nst
& V*cos(w*t+theta)*y(nst*ic+jc+2*nst)
& *y(jc+nst)/hbar
yprime(ic+nst) = yprime(ic+nst) +
& *y(jc)/hbar
end do
end do
end if
return
end
Chris
C BORE - B (CM)
C STROKE - S (CM)
C
C FIND:
C
C NOTES:
C
EXTERNAL RATES
REAL IMEP, MNOT, M
C
C
OMEGA = RPM*PI/30
Y(1) = P1
Y(3) = T1
& DLVLP)
MNOT = V/VU
UNOT = MNOT*U
WRITE(6,10)
WRITE(6,15)
& 'JOULES')
C
C EVERY 10 DEGREES
C
DO 30 I = 1,36
DO 25 J = 1,10
M = EM*MNOT
THETA = THETAE
THETAE = THETA + 1.
25 CONTINUE
30 CONTINUE
C
C
& IER)
UFINAL = U*M
STOP
END
C
& UFINAL
M = EM*MNOT
RAD = THETA*PI/180.
C0 = SQRT(X)
C
C
C
C COMPRESSION
C
& DLVLP)
C = 0.
D = 0.
YPRIME(2) = 0.
GO TO 30
C
C COMBUSTION
C
& DLVLP)
& DLVLPB, IER)
& X**2)*CEE/OMEGA)
& CEE/OMEGA)
& YPRIME(1)/10.
GO TO 30
C
C EXPANSION
C
& IER)
C = 0.
E = 0.
YPRIME(3) = 0.
C
C ALL CASES
C
DO 40 I = 1,N
RETURN
END
C
DATA PI/3.141593/
RAD = THETA*PI/180.
RETURN
END
C
BLOCK DATA
C
END
C
TB = 2000.
DO 10 I = 1,MAXITS
DELT = (HU - HB)/CP
TB = TB + DELT
10 CONTINUE
WRITE(6,20)
RETURN
END
C
C PURPOSE:
C PRODUCTS
C
C GIVEN:
C
C RETURNS:
C MOLE FRACTIONS
C 0 - NORMAL
C
LOGICAL CHECK
C
C FUEL DATA
C
C
C
DATA A0/
C
C
DATA KP/
1 .242484E-08,
2 .344645E-08,
3 -.310227E-08,
4 -.154444E-08,
5 -.162687E-07,
6 -.900227E-08/
C
C MOLECULAR WEIGHTS
C
& 17.009, 30.004/
C
C OTHER DATA
C
C
C
IER = 2
IER = 0
C
C
C
SUM = 0
DO 10 I = 1,10
10 SUM = SUM + Y(I)
DO 30 I = 1,10
30 Y(I) = 0
DO 40 I = 1,6
40 Y(I) = Y0(I)
20 CONTINUE
C
C
C
PATM = .9869233*P
DO 50 I = 1,6
C(3) = K(3)
C(4) = K(4)
D(1) = BETA/ALPHA
C
C
C
TRICK = 10.
ICHECK = 0
DO 5 J = 1,MAXITS
DO 4 JJ = 1,10
A(1,1) = 1. + D103
A(1,3) = D15 + 1.0
A(2,1) = 0.0
A(3,1) = D103
A(3,4) = D26 + D96
A(4,1) = 2.0 +D103
A(4,4) = 0
C
C
SUM = 0
DO 55 I = 1,10
55 SUM = SUM + Y(I)
B(1) = -(SUM - 1.0)
& D(1)*Y(5))
ERROR = 0.
DO 56 L = 3,6
LL = L - 2
56 CONTINUE
5 CONTINUE
IER = 1
C
C
57 DO 60 I = 1,6
& + 2.0*KP(5,I)*T)
DCDT(3) = DKDT(3)
DCDT(4) = DKDT(4)
C
X1 = Y(1)/C(6)
X2 = Y(2)/C(5)
X7 = Y(7)/C(1)
X8 = Y(8)/C(2)
X9 = Y(9)/C(3)
X10 = Y(10)/C(4)
& D(1)*DCDT(6)*X1
& D(2)*DCDP(6)*X1
C
C
DO 70 I = 1,4
70 B(I) = -DFDT(I)
DYDT(3) = B(1)
DYDT(4) = B(2)
DYDT(5) = B(3)
DYDT(6) = B(4)
C
DO 80 I = 1,4
80 B(I) = -DFDP(I)
DYDP(3) = B(1)
DYDP(4) = B(2)
DYDP(5) = B(3)
DYDP(6) = B(4)
C
DO 90 I = 1,10
& + A0(5,I)*T**4
C
C
C
MW = 0.
CP = 0.
H = 0.
S = 0.
MT = 0.
MP = 0.
DO 100 I = 1,10
H = H + H0(I)*Y(I)
MW = MW + M(I)*Y(I)
100 CONTINUE
C
R = RU/MW
V = 10.*R*T/P
H = H*R*T
U = H - R*T
RETURN
END
C
C
C
C PURPOSE:
C GAS MIXTURE
C
C GIVEN:
C
C RETURNS:
C MOLE FRACTIONS
C
C REMARKS:
C AT 298K
C
LOGICAL RICH, LEAN
& S0(6)
C
C FUEL DATA
C
C
C
DATA A/
C
C OTHER DATA
C
C
C
RICH = PHI .GT. 1.0
LEAN = .NOT. RICH
DLVLT = 1.0
DLVLP = -1.0
IF (RICH) GO TO 10
NU(5) = 0.
NU(6) = 0.
DCDT = 0.
GO TO 20
10 Z = 1000./T
A1 = 1.0 - K
& ALPHA*PHI*EPS)
& (2.*NU(5)*A1 + B)
NU(4) = 0.
C
C
20 TMOLES = 0.
DO 30 I = 1,6
MRES = 0.
DO 40 I = 1,6
Y(I) = NU(I)/TMOLES
C
C
C
C
DO 50 I = 1,6
50 Y(I) = Y(I)*YRES
C
C
DO 60 I = 1,6
& A(5,I)*T**4
C
C
C
H = HFUEL*YFUEL
CP = CPFUEL*YFUEL
MW = MFUEL*YFUEL
DO 70 I = 1,6
H = H + H0(I)*Y(I)
C
R = RU/MW
H = R*T*H
U = H - R*T
V = 10.*R*T/P
CP = R*CP
C
RETURN
END
C
C
external fcn
C
C *
C *
C *
C *
C *
C *
C *
C *
C INTEGER N *
C *** ETC *** *
C *
C *
C *
C *
C *
C *
C *
C EQUAL TO N *
C *
C *
C *
C *
C *
C *
C *
C CONTROL) *
C *
C *
C *
C *
C *
C 2/ABS(C(5)) *
C OF 2 *
C *
C *
C *
C *
C *
C *
C OF THE USER *
C *
C *
C *
C *
C *
C *
C . END IF *
C . END CASES . *
C . V *
C . END STAGE 1 . *
C . END IF *
C . END STAGE 4 *
C . END LOOP *
C . *
C STOP *
C *
C
C
C
DO 10 K = 1, 9
C(K) = 0.D0
10 CONTINUE
GO TO 35
15 CONTINUE
DO 20 K = 1, 9
C(K) = DABS(C(K))
20 CONTINUE
DO 25 K = 1, N
25 CONTINUE
30 CONTINUE
35 CONTINUE
C(10) = 2.D0**(-56)
C(11) = 1.D-35
C(20) = X
DO 40 K = 21, 24
C(K) = 0.D0
40 CONTINUE
GO TO 50
C(21) = 0.D0
GO TO 50
C END CASES V
50 CONTINUE
C
C
C * STAGE 4 *
C
99999 CONTINUE
C
C
IND = -1
RETURN
100 CONTINUE
C
105 CONTINUE
C
C(13) = C(3)
TEMP = 0.D0
DO 110 K = 1, N
110 CONTINUE
C(12) = TEMP
GO TO 160
C(12) = 1.D0
GO TO 160
DO 125 K = 1, N
125 CONTINUE
GO TO 160
DO 135 K = 1, N
135 CONTINUE
GO TO 160
DO 145 K = 1, N
145 CONTINUE
C(12) = TEMP
GO TO 160
150 CONTINUE
DO 155 K = 1, N
155 CONTINUE
160 CONTINUE
165 CONTINUE
C
C(15) = C(5)
C
C
IND = -2
RETURN
170 CONTINUE
C
C ANY, ELSE DEFAULT
C(14) = C(4)
GO TO 185
TEMP = 2.D0*C(14)
GO TO 185
180 CONTINUE
C(14) = .5D0*C(14)
185 CONTINUE
C
C
C
IND = 4
RETURN
1111 CONTINUE
C
GO TO 195
190 CONTINUE
C HIT XEND EXACTLY
C(17) = XEND
195 CONTINUE
C
C CALCULATE HTRIAL
C(18) = C(17) - X
C
C END STAGE 1
C
C * YTRIAL. *
C
C
DO 200 K = 1, N
200 CONTINUE
C
DO 205 K = 1, N
205 CONTINUE
C
DO 210 K = 1, N
210 CONTINUE
C
DO 215 K = 1, N
215 CONTINUE
C
DO 220 K = 1, N
220 CONTINUE
C
DO 225 K = 1, N
225 CONTINUE
C
DO 230 K = 1, N
230 CONTINUE
C
C IN W(*,9)
DO 235 K = 1, N
235 CONTINUE
C
C
C END STAGE 2
C
C
DO 300 K = 1, N
300 CONTINUE
C
TEMP = 0.D0
DO 305 K = 1, N
305 CONTINUE
GO TO 360
DO 315 K = 1, N
315 CONTINUE
GO TO 360
DO 325 K = 1, N
325 CONTINUE
GO TO 360
DO 335 K = 1, N
335 CONTINUE
GO TO 360
DO 345 K = 1, N
345 CONTINUE
GO TO 360
350 CONTINUE
DO 355 K = 1, N
355 CONTINUE
360 CONTINUE
C
C STEP IN YTRIAL
C
C END STAGE 3
C
C
IND = 5
C
RETURN
2222 CONTINUE
C
X = C(17)
DO 400 K = 1, N
Y(K) = W(K,9)
400 CONTINUE
C(23) = 0.D0
IND = 3
C(20) = XEND
C(21) = 1.D0
RETURN
405 CONTINUE
GO TO 420
410 CONTINUE
IND = -3
RETURN
415 CONTINUE
420 CONTINUE
C
C END STAGE 4
C
GO TO 99999
C END LOOP
C
500 CONTINUE
C
+ G VALUES-
+ 1PD22.15
+ 1PD22.15
+ 1PD22.15
C
STOP
C
C END ABORT ACTION
C
END
C
C
implicit none
c
include 'fcn.inc'
integer ic, jc
real*8 t
integer neq
dimension neq(4)
minst = neq(2)
maxst = neq(3)
nst = neq(4)
c
do ic = 1, nst
do jc = 1, nst
& cos(w*t+theta)*
& cos(w*t+theta)*
end do
end do
else
do ic = 1, nst
do jc = 1, nst
& *y(jc+nst)/hbar
& *y(jc)/hbar
end do
end do
end if
return
end
RE: Run-time error in engine heat release rate program
I have compiled your code using Salford FTN95 and get your same error message.
However, there is more wrong with this source than just missing routines, my compiler diagnostics are as follows:-
NO ERRORS [<main program>
0141) YPRIME(3) = -C1/CPU/(1. + CO)*(Y(3) - TW) + VU/CPU*DLVLTU*
0142) & YPRIME(1)/10.
WARNING - Variable 'CO' has been used without being given an initial value
0135) E = (1. - X)*(VU**2/CPU/Y(3)*DLVLTU**2 + 10.*VU/Y(1)*DLVLPU)
WARNING - Variable 'DLVLPU' has been used without being given an initial
value
0129) B = C1*(VB/CPB*DLVLTB*C0*(1. - TW/Y(2)) + VU/CPU*DLVLTU*
0130) & (1. - C0)*(1.- TW/Y(3)))
WARNING - Variable 'DLVLTB' has been used without being given an initial
value
NO ERRORS, 3 WARNINGS [<RATES>
NO ERRORS [<AUXLRY>
NO ERRORS [<DATA@>
NO ERRORS [<TINITL>
0370) A(3,2) = 2.0*D14 + D24 + 2.0 + D84 + D04 + D104 - D(2)*D14
WARNING - Variable 'D04' has been used without being given an initial value
NO ERRORS, 1 WARNING [<ECP>
0550) LOGICAL RICH, LEAN
WARNING - Variable 'LEAN' has been given a value but never used
NO ERRORS, 1 WARNING [<FARG>
0681) DOUBLE PRECISION X, Y(N), XEND, TOL, C(*), W(NW,9), TEMP
WARNING - Variable 'TEMP' has been declared but not used
0680) INTEGER N, IND, NW, K
WARNING - Variable 'K' has been declared but not used
NO ERRORS, 2 WARNINGS [<DVERK>
0683) external fcn
*** Missing END SUBROUTINE
WARNING the following symbols are missing:
DVERK
T
LEQIF
AMIN
AMAX
The use of variables that have not been assigned a value is a show stopper, until these are fixed it is not worth finding the missing routines!
