frame and shell sap2000
how to make the shell element and the frama element work together??, I modeled them and for example the shell is at the middle not up as have to be how can i do that
thanks
RE: frame and shell sap2000
to make the shell and frame element work toghter you must connect the frame element to the shell at every node of the shell element, i think that you just connected the frame at its start and end to the shell elemnt.
You must select the frame and the joints of the shell and divide frame at intersection with the selected joints.
dawn386
Are you an employee of Computers and Structures? What is your position, if I may ask?
i am Structural Engineer 3 years experince, i am not empolyee of Computer and Structures.
why you ask?:)
