Design Table and Drawing Views
I have a part that I created a design table for with a default size and three other modified sizes. I was wondering if there is a way to insert three default front views into a drawing, and then utilize the design table to create the other sizes that I need. The way that I did it was to double click the size I wanted in the Configuration tab of the part, and the did a "Save As" and just saved three different instances of the part, then inserted them into the drawing one by one. I really hope this doesn't confuse anybody, and any help would be very appreciated.
Thank You
Charles
RE: Design Table and Drawing Views
1) Place multiple copies of the same view by simply repeating the process used to place the first view.
or
2) After placing one front view, highlight it & do a CTRL+C (or Edit > Copy), then click on an open space in the drawing & do a CTRL+V (or Edit > Paste). Repeat as required.
To change the config, RMB on a view & select Properties, then from the Use named configuration dropdown, select the config you want & click OK.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Thank you....That really helps!!!
Charles
