Stator puller/extractor tool
I am looking for a tool to help remove old stator from their motor casing. We may try a modified 3-jaw internal puller, but I wanted to check if something better already exist on the market (could not find anything on the internet).
Inside stator diameters vary from 4 inch to 7 inch.
Thank you.
Charles
Thank you.
Charles
RE: Stator puller/extractor tool
Jim
Do watch your ventilation using either of them.
Another consideration relating to semi-hermatic rewinds is the fact that the properties of the refridgerent gas used in the system can be affected by the chemicals given off from the insulation materials used in the winding if it overheats and burns out.
