Covert files to a text in a spreadsheet?
Does anyone know of a utility that will take a folder and generate a text file of all the file names? I need to put them in a spreadsheet or database to do some comparisons.
RE: Covert files to a text in a spreadsheet?
I do it like this:
Open Win Explorer, and go to the folder you want to list the files of
Make sure you have the “Display the full path in the address bar” option selected in Tools / Folder Options / View
Click in the address bar and hit CTRL-C (Copy) to copy the path
Open the Command prompt.
Type in “cd”  then paste the path to switch to the folder you want the list of.
Type dir /b /s >Mylist.txt
The file list with all the files and subdirectories will be created in a text file name Mylist.txt in your selected folder root.
... I forgot: the way you paste the path after cd (don't forget the space after cd) is click the right mouse button and select Paste from the pop up.
You can take that one step further and set it up so you can right click on the folder and write that list into that folder
Create a batch file...say in your rootdir C:\ doesn't really matter where as long as you know where it is
In the file named .bat ..you can use notepad the rename ext.
cd "%1"
dir/b/s >mylist.txt
cd\..
exit
then go to win explorer >tools>folder options>file type
click on the one called folder..not file folder..then advanced>new... then you get the new action box
1st line is what you want it to say when you right click on a folder....something like "write list of folder"
in the application used is where you enter the path of the bat file.... c:\writefile.bat
with that dir/b/s... it will write all subs.... so don't do it to far up the tree.. or run the bat by itself at the root level as it will list every file on your drive
you could take the /s off if you only need the files in the first level of the folder
caution.. you have to use regedit to delete the action which really isn't that bad.. do a search for the bat file name in regedit...make sure you type in right the first time and it will be no problem..
Thanks SDO and Cadcamguy
I will give this a try!
No problem... if you need more info out there are quite a few different output methods with Dir... just type
dir/? in a dos window...oops we don't call it dos anymore
command prompt window
