Commerical FEA Software Code
This is just a curiosity question. Are there any commerical FEA software that have their code written in mathematical software like Matlab, Mathmatica or Maple? I am guessing the answer is "NO". Can anyone tell me why? Thanks
RE: Commerical FEA Software Code
I routinely run half million node models of tet meshed solids through Abaqus, Lusas and Nastran on PC's with run times of less than an hour for linear analyses and models a quarter of this size non-linearily. I doubt very much whether any of the above mentioned will even come remotely close to doing this.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Good point, Johnhors and Drej! In effect, the "lower-level" the language, the faster the routine: if one was able to program in Assembly with the Intel datasheet of processor's registries and built-in functions, for sure his "home-made" code for FE solving would be as fast, if not faster, as the main commercial FE packages.
Programming in Matlab or Mathematica means that your program must first pass through the MatXXXX interpreter, a higher-level one:
Processor -> HardwareAbstractionLayer -> (OperatingSystem) can be bypassed -> Interpreter -> ProgramShell -> ProgramInterpreter -> Routine.
If one knows exactly how to do (I don't !!!), he can operate at OS' level, or even below the HAL.
Otherwise, his routine would be enormously slower.
Bye!
As for the second statement, writing your own code in assembler and beeing faster than the commercial one. I'm not so sure about that. I've heard that in some commercial codes the numbercrunching the routines are programmed in assembler. Maybe somebody knows more as to "who and how" but I imagine that doing for example the matrix decomposition in assembler would be an advantage.
Thomas
I agree that programming FEA by using front end Matlab, Mathematica etc. commands will be probably easier but the code will be much slower.
About FEMLAB , it probably takes advantage of some underlying compiled MATLAB numerical libraries than using interpreted front end commands.
By the way I always have had this question:
why a non object-oriented FORTRAN language (which I personally consider being obsolete and rather rigid) is preferred to an object-oriented language (e.g. C++) by the FEA software developers ???
Wow !
Well what help is an object oriented language in solving FE problems? As for obsolete and rigid, Fortran 95 I find very flexible and easy to program in, especially the memory handling routines. Long gone are the days when arrays had to be sized by the largest problem considered practical, which made small problems also run very slowly. Nowadays a well written Fortran program will solve small problems like greased lightning and solve big problems with efficient use of available memory resources.
The front end gui's for pre and post processing may well be written in C++ or make use of off the shelf libraries like TCL/TK but Fortran can also handle standard windows gui's and OpenGL graphics just as easily as any other language.
Note that when several of todays big commercial codes were born Fortran was king in that department and to rewrite hundreds of thousands of lines of code today just to get from Fortran to C++. Like I said, I don't se the point.
As for MATLAB, FEMLAB etc. A professor once told me that to test a new algoritm using MATLAB takes perhaps a week of codewriting and a day to run the problem. To do the same thing in Fortran would take a month to write and an hour to run. Of course these are no absolute numbers but the idea is that if you want to write your own code MATLAB might be a good platform. However, if you want to run large reallife problems you might need something else. Don't get me wrong, I like MATLAB but I'm not sure I would run a million dofs problem on it.
Thomas
Since Matlab does not interact with the hardware like other low-level languages it takes longer to run the code. And when the dofs involved is large that makes it even more painful. Hope I got it right. Thanks
ahad
don't take me wrong. I don't think FORTRAN code could not do its task as well as any other compiled code...
But..
...I was only thinking from a developer point of view. An object oriented language is much more flexible and allow the developing of more complex, maintainable and easy-to-update code.
