Problems w/DT & Excel Sheets allowed?
I keep getting the error message "no valid design sheet found" except when I open the design sheet in a separate window, then it recognizes it and works fine. Does anyone know why? I am using an excel file with several sheets (each sheet a separate Design Table), is this a problem? I know the DT is setup right because it works when opened in a separate window. I'm using v2003. Thanks for any advice.
RE: Problems w/DT & Excel Sheets allowed?
In additon check that you have a emty row under your configuration name.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
