FDA Solid Film Lube
FDA Solid Film Lube
FDA Solid Film Lube
Anyone know of a FDA approved solid film lubricant for stainless steel parts?
RE: FDA Solid Film Lube
What kind of parts?
stainless steel
Are you looking for a sheet or a spray on lubricant?
Is it to coat the parts or to let the parts slide across?
Some more definition of your exact need would help get more response.  Jster91 was asking for more description of what the part looks like, size, surface features, difficulties of application design features, or what is its function, etc., not a repeat of the material, which you had already stated in your original question.
Solid film lubricant for SS parts - PFA of FEP teflon.
