Rebar Calculations for a simple concrete structure
I am designing a concrete box that is 13.5 m long by 4.5 m wide by 5.1 m deep. I need to calculate the moments of each wall and the moments acting on the floor. A simple moment calculation if the force x distance where the force is acting. Now I have read a couple of books where they have used weigth of wall/floor (wf) x span (ln) squared x 1/8. I am a little confused and could use some insite into this.
RE: Rebar Calculations for a simple concrete structure
Just be glad you don't have to do this on a hand crank Marchant Calculator, as we did.
If all else fails, let me know and I'll send you a copy so you can set up a spreadsheet to do the calc's.
Good luck
