JOINING OF CR STRIP
JOINING OF CR STRIP
JOINING OF CR STRIP
What is the best process to fuse or join CR strip of 0.1mm thich to maintain continuity on CR mill?Its a SS grade od 304,308 .
RE: JOINING OF CR STRIP
hi Ed
its ok that autogenous welding will work here but will be source of haet i.e. welding process.Plz help me
Thats ok but the thing can you have some practical data about this application wrt to excat process because only TIG wont do either TIG with mocro plasma or some laser will do this job.
