CONDENSATE SUMP WALLS
NEED TO TAKE SOME CORE SAMPLES OF A CONDENSATE SUMP WALL
FOR CONCRETE TESTING PURPOSES. THE SUMP CONTAINS CONDENSATED STEAM MIXED WITH SOME HYDROCARBONS. WHAT WOULD BE THE BEST AND QUICKEST WAY TO REPAIR OR PATCH THE HOLES??
IF NEGATIVE RESULTS ARE OBTAINED FROM CONCRETE TESTING (COMPRESSIVE STRENGTH) OR CRACKS ARE OBSERVED ON WALL AFTER DRAINING THE SUMP, WHAT WOULD BE A GOOD APROACH TO REPAIR THE WALLS. THESE WALLS SUPPORT A STRUCTURE WHICH SUPPORTS SOME PIPING.
RE: CONDENSATE SUMP WALLS
