Transformer nomenclature in Asia
Can someone please explain the nomenclature listed below.  It came off a 31.5MVA Transformer, (110kV-6.6kV,
Y-Y connect   Ynyn0(d11)
RE: Transformer nomenclature in Asia
The transformer is wye-wye with a neutral brought out on both sides and no phase shift between the two wye windings.  There is also a delta tertiary winding that leads the wye windings by 30 degrees.
