Cable Heating From Using Steel Conduit Elbows?
5
We had an interesting situation come up here recently...wondering if anyone had seen anything like this:
The city was seeing intermittent trips on a 15kV breaker which was tied to an underground feeder.  Within a week, one of the phases (they run each phase in a separate conduit), faulted.  They pulled the faulted cable out and replaced it.  Within a week, another phase faulted.  Both of the faults occurred at a 90 degree turn in the conduit.  The conduits were installed as pvc with steel elbows at the turns.  The cable manufacturer said that by using the steel elbows, the magnetics would create heat causing the breakdown.  The city only was using about 60 percent of that cable's capacity so I can't see how the magnetic heating effect could create enough heat to push the cable's temperature high enough to create that fault. Any thoughts/comments?
RE: Cable Heating From Using Steel Conduit Elbows?
Was bend radius OK? Also, was the cable pulled with excessive force through the bend?
Gunnar Englund
www.gke.org
It was the electric heating caused by steel elbow enclosing a net current.  That steel elbow will run very hot in the situation you describe.  Either the steel elbows have to go, or you have to use smaller conductors and pull all three phases in all three conduits.
I have seen this happen before, so I would tend to agree with the cable supplier.  Cable insulation melted in steel elbows causing a fault.
I have also gotten calls from clients asking why the conduit elbows were too hot to touch.
This would seem to be the most likely cause of failure unless you have a better candidate.
As I'm sure you know, if all three phases are run in one conduit, this is not a problem because the net flux is close to zero.
davidbeach is right..not sure what 'net' current means, but running single phase conductor in a metal conduit will induce currents in the conduit/elbow to heat up.
I believe the installation was okay.  Another specific - the manufacturer said that by installing cable in this fashion (one cable per conduit), the cable will be derated by up to 50 percent.  He said if three cables had been installed per conduit it wouldn't have been a problem since the magnetic fields would have cancelled out.
net current is the phasor sum of the current(s) flowing in the conductor(s) in question.  With one conductor, it is the current in the conductor.  With three phase conductors (and a neutral if applicable) the net current would be the phasor sum of all conductors and should be very close to zero.
So this is caused by the three elbows interacting as a crummy transformer?  Would this still happen if an indiviual phase was in a steel bend 30 ft from the other phases?
itsmoked, it's three independent transformers, proximity does not play a role.  Check NEC 300.20.
Tefaber,
Davidbeach is right on the mark.
You ask if anyone has seen anything like this: We had a similar situation when someone installed a steel Unistrut frame supporting the line connections to a 56MVA generator and through lack of knowledge managed to form a closed loop around each phase. The support was running so hot that the galvanised finish was failing and the underlying steel was coloured by oxide.
You may also encounter seemingly strange brass or aluminium fittings on single core cables. Aluminium cable armour, aluminium glands, brass gland plates are all typical for single core AC cable installations. These components are used to avoid the magnetic induction problem which you have observed. Single cores are usually installed in a trefoil group to minimise the external magnetic field and are cleated together to withstand the large electromagnetic forces which exist during fault conditions.
If we learn from our mistakes,
I'm getting a great education!
Thanks davidbeach.
This has nothing to do with the *bend* either, only that it is a closed magnetic path around the cable?
itsmoked, yep, the bend is irrelevant; somebody thought it would make a stronger system to have steel els in a phase segregated system - big mistake.  They just needed to learn that pulling with a steel rope won't burn through PVC els like nylon rope will.
A steel rope or cable will saw through PVC and steel elbows. Bare steel or nylon coated the results are the same. Been there seen it happen. In addition to being a good saw both steel and nylon store a lot of energy in streaching and are very dangerous.  Large diameter ropes with parallel strands covered are the only way to go.  The local electrican store has non- streach ropes.
One you saw even a little nick in an elbow you cable is compromised.
tefaber,
This really is not a good installation and  violates NEC Article 300 as David Beach has pointed out.  It needs to be corrected.
There is no provision in the NEC for derating a conductor due to magnetic heating of the enclosing raceway.  The conductor is supposed to be installed in such a way that the magnetic heating does not occur.
Do the city and yourself a favor and make sure it gets corrected.  Let us know how it works out.
Quote (BJC):
Not true.  A steel hard line allows pulls through PVC elbows without burn through where a nylon rope would burn the PVC.  Now, if the bend is too tight it won't matter what is used for a pull-line, you'll have burning.
There is much less friction between steel and PVC than there is between nylon and PVC, and the steel can disperse the heat much better than a nylon rope.  The stretching of the nylon rope only further compounds the problem.
Check with the cable manufacturer's for their recommendations for pulling and you'll find that they recommend steel rope.
Have check many times and pulled many miles of cable.  The only advantage to steel cable is when you saw all the way through a steel elbow the induction heating problem goes away.
hehehe Good point.
Thanks for those clarifications davidbeach!
Excuse me. I'm not convinced.
That induction heat thing is so well-known that I thought it could be excluded. Also, we have not got any information about current in the cables. Only that "The city only was using about 60 percent of that cable's capacity so I can't see how the magnetic heating effect could create enough heat to push the cable's temperature high enough to create that fault"
The OP has already contemplated the effect of induction heating and asks for comments. A cable carrying 60 % current causes about 36 % heating and since the elbow probably is surrounded by dirt, I think that the cooling is adequate.
Many questions remain unanswered. The main question is: What is the rated current? Other questions are: Bend radius? Vertical stretches that put constant pull forces on the cables? Surrounding material? Dimensions of cable and elbow? Elbow materiel? (Sheet steel, stainless, cast iron?) Dimensions, current, material and cooling have an influence on temperature rise. Many installations are OK even if there is one phase per steel tube or elbow.
I find it too easy to say that magnetic heating is the cause. It may very well be so, but that effect is so well known by all people in the trade that a (conscious) violation seems unlikely. The OP does hint that there might be some other effect. Let's find out if there is.
There might even be a short-term overload that has hitherto gone unnoticed. A 1 hour peak recorder does not tell you the whole truth.
Gunnar Englund
www.gke.org
We did case studies with mock ups for our project and the heating in very short runs of steel conduit (bulkhead penetrators) with single phase cable was surprising.  All of our penetrations are specified as "non-magnetic".
skogsgurra, 60% current equating to 36% heating would apply to I^2*R type of heating of the conductors.  In the case of induction heating due to magnetic enclosures around a single conductor, the heating has a multiplier of much more than one.  If all three phase conductors passed through one steel elbow there would be no heating (if a balanced circuit), so we have far more than 36% heating.
Yes, it is a well known issue, but apparently not by who ever did the installation.  With those elbows in that installation they will always have problems, whether there are other contributing factors or not.  There's not much point trying to figure out the minute contributions to the cable heating (which would be relatively uniformly distributed if it were overload related) while the significant source of heating remains.
Elbows is one of the areas were cable are exposed to high mechanical stresses do to wall pressure during the installation phase. If additional stresses are added in this area during cable operation, a premature failure may happen sooner than anticipated. Here is a possible scenario to explain the premature failure in the cable:
Single conductor cable routed in separate ferrous metallic conduits produce a magnetic field induction creating circulating current throughout the metal conduit elbow. The heat generated by the Joule effect (RI^2) may exceed the thermal rating causing a premature failure in the insulation.
Quote:
Cables in ac circuits should not be installed with each phase in separate magnetic conduits under any circumstances due to the high inductance under such conditions. Cables in a-c circuits should not be installed with each phase in separate metallic non-magnetic conduit when their size exceeds 4/0 unless the conduit is insulated to prevent circulating currents.
http://www.okonite.com/engineering/shielding.html
Elbows do cause mechanical stress during pulls, but that is stress to all of the cable that passed through the elbow.  Since both failures are reported to have occurred at the elbows, I would not suspect pulling damage as that would show up at random locations beyond the elbow.
Davibeach,
Failure on any electrical component is characterized by the sum of the stresses in time.
We are suspecting the thermal stresses are the lead cause of failure and we may add that metallic elbow is not a good engineering practice with single conductor cable. However, at this moment there is not sufficient information to rule out any potential combination of causes or determine the exact reason of the failure.
cuky2000, I completely agree with your first statement.
On the second statement, while there may be other contributing factors the description of the failures is exactly what is to be expected given the steel elbows.  With an installation problem known to cause the exact failure found, and a problem that is expected to cause such failures in the future, why look for other possible causes rather than just dealing with the one?
Davidbeach,
I appreciate the education, but I still insist that the magnetic heating is (close to) an I2R effect. It is well known that hysterisis has a slightly higher exponent. Steinmetz, I think, used 2.3 - 2.6 for hysterisis heating. Depending on steel quality, frequency and penetration.
The eddy current effect is a pure I2R effect. It is hard to know which effect is dominant as long as we do not have data from the installation.
So, with the higher exponent (2.6 instead of 2) the resulting heat would be even less at 60 percent current - about 13 or 14 percent. If we only have eddy currents, it would be 36 percent. As said before.
What I mean to say is that one should not always jump to the first conclusion that presents itself. It is sometimes wise to think twice - or thrice.
Gunnar Englund
www.gke.org
skogsgurra,  I haven't tried to figure out or look up the effect of additional current on inductive heating, so you may well be correct on the impact of additional current on the amount of heating.  My point is that it is the unbalanced current that is doing the heating.  If all three phases had been installed in one conduit, the amount of current doing the inductive heating, even with the cables carrying their maximum current, would be very close to zero.  In the case under consideration, the current causing the heating is many, many times that near zero value.  If the expected net (zero-sequence) current were 5% of rated current, we are now seeing 60%, or about 12 times.  Square that 12 (or raise it to the 2.6 power if you wish).  Now we are looking at 15,000% {',' per US convention of thousand's separator, not European convention of radix} or more, of the heating that would occur with limited net current.  Even if the heating to be expected for a balanced 3-phase were extremely small, 15,000% of that amount can be enough to cause significant damage.  It is that extreme heating compared to the balanced three-phase case (or a properly constructed segregated phase installation) that makes me question the need to find other causes.
When there's a four foot diameter hole in the bottom of the boat, why look for slow leaks around the joints?
Sorry davidbeach, I know all these things. Including the "news" that currents in a three-phase cable cancel.
The OP presented the "four foot diameter hole" and said that he would like some comments and thoughts beyond that. That is what I have tried to give him. I am sorry that you do not like that.
Gunnar Englund
www.gke.org
skogsgurra,  the way I read the question, he was discounting the possibility of heating caused by the steel elbows.  What I took was the cable manufacturer blamed the steel elbows, but the OP wanted to find the "real reason".  My guess is that the steel elbows will be quite difficult (expensive) to get to and replace and he wants a magic bullet.
I read your comments as discounting the possibility of the steel elbows generating enough heat to cause the problem, if that was not your intent, I'm sorry I misread.
Sure, there could be many other things wrong with that circuit, but as long as those steel elbows are in place, the other problems won't have enough time to develop a failure before the elbows melt the insulation again.
Agree. I do not usually "behold the mote that is in my brother's eye, without considering the beam that is in mine own eye" Or how to put it. I wouldn't have done that (using steel elbows) either. We cannot get any further than this, I guess.
Gunnar Englund
www.gke.org
One minor addition might be that a contributing cause to "the failure always occuring at the elbows" is that that's the (only/best) conductive path to ground or another phase, the rest of the run having the individual conductors enclosed in pvc and even if badly stripped would stand up longer than at the steel elbows.  Even if so, still doesn't change the fact that the elbows need to be changed out due to magnetic heating.
Pechez les vaches.
Also, the steel elbows are probably not solidly grounded resulting in step potentials when a ground fault current does occur.
You can get an installation that is very mechanically strong by encasing PVC elbows in concrete. Just be careful that rebars do not go in between phases which will also create an induction heating hazard. ( NB: Rebars really only need to be on the outside of the concrete encasement anyways. ) For an important feeder or circuit concrete encasement increases circuit integrity. Having 6 to 12 inches of concrete over the topmost conduit provides better protection against digins and coloring the concrete red porvides even better protection yet.
Also, concrete encasement helps spread out heat particularly if your soil presents a lot of heat resistance. If your soil is sandy you most definitely need to use concrete to spread out the heat.
Also, where nylon or steel rope saws into elbows is if the elbow has too small of a radius OR the rope is too small in diameter. We use nylon rope for a lot of wire pulling but it is either Jetline twine or more like 1/2 inch. The problem with high strength ropes is to use a smaller diameter ropes which creates more sawing pressure at elbows. If the sawing pressure is low enough sawing does not occur.
You can also use polypropylene rope if you would rather use a large diameter rope but be very careful of what you buy. The polypropylene rope that is rated for installing and removing submersible well pumps is very good stuff. There are basically 2 grades of polypropylene rope which is the really good stuff that is rated against rotting due to water exposure and cheap crap. The cheap stuff also tends to break without warning because the fibers are of unequal strength and other quality problems.
When I was moving a factory I liked to use 1/4 inch polypropylene rope for up to 100 amp wire pulls and 3/8 nylon for 200 amp wire pulls. The latter was pulled in using a set of sheaves that redirected the rope so that we could use a forklift truck. Any vehicle with a torque converter makes for an excellent wire pulling machine.
Thanks for all the information, it has been very insightful.  One more question.  Are there any possible solutions to this problem besides removing the cable/elbows altogther.  Can the IR effect be minimized by insulating the elbows?  Perhaps some type of backfill?  Any thoughts?
If there's any way to make a longitudinal cut in the elbows-in-place, you might not need to remove them.  Requires that they not be touching each other, and have no magnetic or conductive contact with each other.  The cut needs to be wide enough to ensure that eg. backfilling etc. won't force the edges together.  Best would be to cut in the back of the elbows, eg. not where pulling/or/tight wires would contact the cuts.
Note to others, this is certainly not recommended practice except possibly as a one-time emergency fix for this particular situation.
Pechez les vaches.
lengould is correct that cutting the elbows, parallel to the conductors, will solve the problem.  Getting to the elbows to do that much seems to be most of the work necessary to remove and replace the steel elbows with PVC.  The problem is not an IR effect, it is an electromagnetic effect and will be entirely unaffected by insulation between the conductor and the elbow.
The only way of eliminating the effect without removing the elbows or cutting them would be to short each elbow to the conductor enclosed, at both ends of the elbow.  That would eliminate the heating, but then you would need 15kV insulation on the outside of the elbow.  THIS IS NOT A RECOMMENDED SOLUTION.
tefaber,
It might be possible to remove the conductors and re-pull them such that there are A-B-C phase in each conduit, depending on the conductor size, conduit size, etc.  I have done this before for fairly short runs where the client had three conductors per phase.  It's a lot of work, but if the conduit is embedded in concrete, it might be worth thinking about.  You might have to re-conductor to get a configuration that works with the existing conduits.
Splitting the steel elbow as mentioned would solve the heating problem, but then you would have created
other problems.  If you're a consultant or engineer-of-record, you should try to steer them toward a permanent solution that complies with NEC.
If they choose another path, then at least you tried.
I agree, it should be fixed the right way.  The city had used this installation on their 4kV system as well, but they haven't had any problems with it...only the installations on the 13kV system.  Do you think the city can get away with the 4kV installations due to the reduced voltage?  Any thoughts?  Thanks again.
Heating due to induction should be entirely a function of amperage, voltage should not be a factor in what temperature the elbows come to, though it may be a factor in whether the resulting heat breaks down the insulation.  Likely the lower voltage runs can put up with the added heat load for some reason, ie. not loaded so close to their current limit, less current per unit elbow diameter so lower temperature, different cable construction etc.
Pechez les vaches.
What lengould said.  Induced current is simply a function of net current within the conduit.
I would be very cautious of the 4 kV system if it is installed the same way.  You'd want to recommend fixing them both, since both are NEC violations.
Interesting, indeed.
We have yet to know what currents were involved in the 13 kV  and the 4 kV systems.
We know that there were not more than 60 percent of rated current in the 13 kV system - which failed. How many amperes would that be?
And how many amperes are there in the sucessful 4 kV system?
Please, tefaber, we need that information to be able to judge this case correctly.
Gunnar Englund
www.gke.org
Right.  Sorry - the 13kV circuit is 750URD rated at 535 Amps and was pulling about 60 percent of that at the time of the fault.  The 4kV circuit used 500kcmil cable, rated at 430 Amps.  It is pulling around 80 percent.
Interesting.
You have 535x0.60 = 321 amps in the 13 kV circuit. And 430x.80 = 344 amps in your 4 kV circuit.
And you have what is supposed to be magnetic heating in the 13 kV circuit and not in the 4 kV circuit (where you actually seem to have a higher current). Are conditions comparable otherwise? I do not understand US cable numbers - is the 4 kV cable a single phase cable like the 13 kV cable is?
Gunnar Englund
www.gke.org
I had an experience with this phenomenon years ago at the beginning of my career.
We were sent out to wire a large submersible well pump, something along the lines of 200hp. When we got to the site there were three individual conductors stubbed out of 3-1" threaded hubs on the top of the wellhead. Re-pulling the cable was not an option, the well was several hundred feet deep with the motor at the bottom. My boss at the time decides to use 3 1 x 12 rigid nipples to support a junction box, running each wire of the 3 phase through it own nipple. When we started it up it was a matter of seconds before the 12" nipples were too hot to touch.
We bought aluminum nipples, sawed between the knockouts in the junction box like NEC requires, end of heating problem. The top of the well head with the three hubs was cast iron, I realize there were eddy currents there, but the mass of the casting and the cold water moving past kept it cool.
