Moment of Inertia for a 2D section view in drafting
Hi there,
I would like to know whether, there is any way I could get the 2D moment of inertia values of a section view in drafting module.
Also like to know, if I could get the 2D moment of inertia values from a split assembly (MI for whole assembly), I was able to get MI values for individual parts, but not the whole assembly as such. I'am using Catia V5 R14.
Thanks in advance,
Sandy
Thanks in advance,
Sandy
RE: Moment of Inertia for a 2D section view in drafting
Please note, that while I have said to use the part, instead of the assembly for analyzing this way, you can easily bounce in and out of models without getting confused, by using the Edit -> Links menu. From there, you can select your model from a list, and either double click, or use the "Open" button to bring it in as a stand alone part, without fumbling your position in the assembly tree. (and just close it without saving when you are finished, if you choose)
As for the assembly - you just need to hold down the Control key while selecting. Select assembly components from the tree, (while holding Control) and you should notice that as you do so, the text box called "selection" will change from a single instance, to a value called "multiselection."
Hope that helps
Check out CATBlog!
Check out CATBlog!
I don't have V4 anymore to verify this, but try adding a pattern (shape) to your section, and then analyze the shape. I think it will include some of the information you're looking for.
If it's a 2D section, it won't be Mass Inertia, will it?
