Setting up Formats
Setting up Formats
Setting up Formats
Hi Folks,
Need some help again!
I am setting up drawings formats (*.frm) at the moment.
How do I place the tables accurately with regard to each other and also with regard to the paper outline? There does not seem to be a sketcher with dimensions, which would be ideal. Is there a ‘place’ function or snap type command.
Is it me or is PRO-E very user-unfriendly?
Thanks Again,
Speedy.
RE: Setting up Formats
Speedy,
To Move a Table Within a Single Sheet of a Drawing
1. Choose TABLE > Move.
2. Select one of the corners of the table to move.
3. Select a new position for that corner.
4. To move a table to another sheet, choose Switch Sheet from the SHEETS menu.
When you have picked the table you can also choose absolute coordinates or relative coordinates.  I agree it is a pain.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 3.1 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Turn on "Snap to Grid" under the environment icon and adjust your draft grid so that it correlates to the line spacing on your drawing format (e.g. 1 mm, .0625", .050").
Andy
