Flatten Helical sweep
How do you create a flat pattern of / flatten a helical sweep with constant or variable pitch in Wildfire 2 ??
RE: Flatten Helical sweep
*Unless* it is a helical sweep where the broad surface of the sheetmetal is parallel to the axis (i.e. like a spiral tube). Then you should be able use the unbend all or flat pattern tool.
