Sea water corrosion
Sea water corrosion
I've received a material selection where seawater is used first to cool down process water and then reinjected into an oil well. For the first part of the seawater circuit (from intake to deaeration tower) FRP pipes are proposed, then CS pipes with 3 mm CA. Shouldn't be preferable to adopt CRA (such as SS or Duplex) for the second part of the circuit?
RE: Sea water corrosion
Really, superduplex is the best bet. You can do it in CS, but maint. will be an issue.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
ww
