Coordinate Dimension Table
Hi Could somebody advise me is there is any way to update point tables after they have been created. Is there any way of linking the table and the space point.
RE: Coordinate Dimension Table
If you're talking V5, I'm putting together a tutorial on design tables (V5) right now. I'll be linking to the FAQ, and the FAQ will point you to the CATBlog when it's finished.
Check out CATBlog!
How do you create a points table? What is a points table?
We have to do drawings specifing Global XYZ position for edge positions. I've traditionally done this by manually creating a table by manually typing out the measurments from the CATPart window. I'll give our helpdesk a ring if this is what it is.
Darren
There is no way that I know of to make these associative, unless you are clever enough to associate the values to a design table. I have not attempted to do this, so I'm not 100% certain that it can be done.
You can manually change the values, but it is really funky the way that the table handles. You have to click and/or double click in "just the right way." It's very awkward.
If you need further instruction in how to modify the values, let me know. I'll do my best.
Check out CATBlog!
System is HP AIX
V5 R14 sp3 DaimlerChrysler environment
Sorry.
Check out CATBlog!
But how do I do it
Use the last pull down on the right, in that tool palette to adjust the decimal precision.
Again, for your selection to be of any effect, you MUST choose it BEFORE you select the points.
Otherwise, I would refer you to the numerous recent threads regarding standards, to set the default precision.
Check out CATBlog!
On Windows it works perfectly but Unix does not work
thanks for your help
Check out CATBlog!
