Tabulated basic dims
Here is a new one for me. I have a part with a lot of holes (patterned). I have the first hole dimensioned from two directions X,Y that are tabulated in a Excel worksheet on the dwg. The dimensions have overrides with letters (F, G) as the variables. The letters corrispond with the tab block. Is there a way to enclose the letters as if they are basic dimensions either at the dim or in the Excel worksheet? Once the dim is override with a letter, it can not change to a type of tol.
Hope I made sense. thanks
[URL=http://img292.imageshack.us/my.php?image=holedims2aw.jpg][IMG]http://img292.imageshack.us/img292/6720/holedims2aw.th.jpg[/IMG][/URL]
Chris, Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Tabulated basic dims
WorkingLife (Mechanical)
Hi Chris,
Instead of simply using "F" to override the dimension, if you type in "<SL-#>" where # is your letter, you can get your basic dimension that you want.
That worked. Thank you much.
FAQ559-1100
FAQ559-716
brengine (Mechanical)
WorkingLife,
Do you know where you learned about the "<SL-#>" functionality? Is it in the Help somewhere, or maybe the Calloutformat.txt file? I'd like to see what else is available.
Ken
This was a great tip. You can also use cl and tl for circle & triangle. We also use this format at our company, but I'm looking for a way to insert a letter in an inspection symbol with the word "inside" underneath. When you place a word underneath the letter, the inspection symbol switches to the word and doesn't remain on the letter. There are a number of work-arounds, but it would be easier if there was a similar way to do this.
Thanks, Sylvia
F.Y.I. - <CL-#> & <TL-#> must be capitalized.
If you need more functionality, there are more out there Ken.
If you click on the dimension in drawing, you will be given a properties on the left side.  Under the "dimension text" box, there's a "More..." button.  After adding one that you want, there's where I got the code for all the other possibilities.
I don't believe there's a help for it, but there should be.
Allan Chun
SolidWorks CSWP
Great tip. I've had the need for this type of feature myself.
One question, maybe I missed it:  Is there a way to have more than 1 character?
Christopher Zona - Senior CAD Designer
Litens Automotive Partnership
Concord, Ontario
yes you can have up to 99 in the numbers and ZZ in letters.
Ex: For numbers <S-99>
Ex: For letters <S-ZZ>
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
  Information identified as <CL-#>, <TL-#>, etc., are all SolidWorks Symbols.
  Symbols are identified in the file "gtol.sym" located in:
SW-LoadPoint\lang\english
  In addition to the "Flag" Symbols above, the file defines all GD&T, Weld, Hole & Modifying symbols.
  If necessary, the file can be modified to include your own specialized symbols.
  CAUTION: Once modified, it is your responsibility to maintain through future revisions and for multi-user environments.
