Joining broken zinc casting
Anyone have any techniques they have used successfully to repair a small zinc casting (<1/4 lb)? This item has sentimental value to the owner and has become a challenge to me!
Griffy
Griffy
RE: Joining broken zinc casting
regards,
Hydroformer
Also looked at tin/lead solder but had no luck there. Low melting point and rapid heat transmission rule out silver solder.
Thought about TIG with a backing dam but I am uncertain what might work as a filler.
If all else fails, I may use the parts to make a mold and cast a new one.
Griffy
http://www.solder-it.com/
There are number of solders that will work but the secret is in the flux. It was no problem when you could use Cadmium in the solder
*Without data, you're just another person with an opinion.*
Hydroformer
Lol, near parallel post.
Hydroformer
It also has some nasty health effects.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessor.com
