Want help about Admin tool
Hi I want to find information about the administation tool, standard setting, in clear detail
please help me !!!
RE: Want help about Admin tool
What is the administration tool, standard setting?
Better yet, what are you trying to do?
Check out CATBlog!
I want to modify the setting of dimension, text format
This topic was recently posted, and developed very well.
This is *definitely* a topic that you need to search the forum for.
Check out CATBlog!
In the search field type " XML standard "
Also you can search / look the Dassault CATIA Online Doc about standards and XML files.
Then tell us what you do not understand, but giving you here the comlete story about standard/XML might be too long.
Eric N.
