broken-out section view
Does anyone know how to remove or reposition the outline for a broken-out section view in V14 ?.
I know that to get rid of the sectioning you can set the view properties to not sectioned, but that will not allow me to show a new broken-out section
beachcomber
beachcomber
RE: broken-out section view
Right click on the view where the broken out section view was applied, choose 'properties'. Then, go to the 'general' tab and check the option 'Show broken out section view profile'. Click 'OK'. Then, you can select the border that appeared and edit the profile or the depth (ribbon bar).
Fred
Sometimes it's the really simple stuff that trips you up.
