special animations
special animations
Hi Guys,
I am doing some pretty simple cad work, just creating some decent 3d to make some presentations look a bit smarter, i was wondering if there is a way to take a solid block and animate it so it seperates into individual 3d text characters?
Any help on this would be great, as i am not that experienced with the animations side of solidworks.
Pete
Pete
RE: special animations
Chris, Sr. Mechanical Designer, CAD
Theophilus (Mechanical)
You can do this if your bits and pieces are coming apart or joining together instead of actually shifting shape. For shape-shifting and morphing, you'll probably need to use something more like 3D Studio Max or Alias, etc.
CorBlimeyLimey (Mechanical)
Check out the Split Part animation at h ttp://www. mikejwilso n.com/soli dworks/sol idworks_fi les-02.htm
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Otherwise, SW models tend to be what they are. Assembly animations generally assume fixed-shape parts moving in relation to one another.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
It may give you some ideas.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
