Modify Pattern via Pro/Toolkit
Hi all,
i am writing a Pro/Toolkit Application, that can modify dimensions and pattern. The application can now modify dimensions but not for pattern. Is there any body, who has accessed pattern via Pro/Toolkit? Will you me some hints?
Zuardy
RE: Modify Pattern via Pro/Toolkit
Hi zuardy,
it would be nice if you could explain your problem a bit more explicitly. maybe then i can help you a bit...
debanjan
Hi Debanjan,
first thank for the response.
Below is part of my codes. It fails on the call of ProValueDataGet(). I am not sure, that i have the right array/tree of elempath_data[]. May be i have misunderstood the description about Element tree in the Pro/Toolkit manual. What i want to do with Pattern is just modifying his member number, i.e, PRO_E_PAT_FIRST_DIR_NUM_INST.
Thanks in advance.
Zuardy
static ProElempathItem  elempath_data[] = {
    {PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_PATTERN_ROOT},
    {PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_PAT_TYPE},
    {PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_PAT_REF},
         PRO_E_PAT_REGEN_METHOD},
    {PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_PAT_FIRST_DIR},
         PRO_E_PAT_DIR_DIM_COMPOUND},
         PRO_E_PAT_DIR_DIMENSION},
         PRO_E_PAT_DIR_VAR_TYPE},
        PRO_E_PAT_RELATION_EDIT},
         PRO_E_PAT_FIRST_DIR_NUM_INST}
ProElempathAlloc(&p_elem_path);
nStatus = ProElempathDataSet(p_elem_path, elempath_data, 4);
if (nStatus == PRO_TK_NO_ERROR) {
  ProValueAlloc(&p_value);
  nStatus = ProFeatureElemValueGet(&feat,
                                   p_elem_path, &p_value);
      nStatus = ProValueDataGet(p_value, &value_data);
      fprintf(pVisitData->pFile, "Number of Pattern = \
                  %d\n", value_data.v);
      else { //Error occured
      fprintf(pVisitData->pFile, "Error at function\
          ProValueDataGet\n");
     fprintf(pVisitData->pFile, "ProFeatureElemValueGet\
         return %d\n", (int) nStatus);
  nStatus = ProValueFree(p_value);
  if (nStatus != PRO_TK_NO_ERROR) {
      fprintf(pVisitData->pFile, "Error %d in module: %s, \
              line %d. \n", nStatus, __FILE__, __LINE__);
       return ((int) nStatus);
hi Debanjan,
thanks for your hint on this adress
regards,
zuardy
