Femap V9.0 force vectors
I’m using an NE Nastran and Femap 9.0. The problem is that I can’t possibly remove the constraint force vectors. Those vectors are still in place although “Deformed style” is setted to “None”. That’s not desirable when I want to present the element model without vectors. The only way to remove the vectors is to delete output set.
RE: Femap V9.0 force vectors
Good Luck
Thomas
