metering a 3phase splitter
We want to put an electric meter to measure out the Kwh were using in our 600v, 200 amp, 3 phase, no neutral splitter feeding our machineries in one portion of our plant,  what kind of meter is best to install and is there a 600 volt meter?
RE: metering a 3phase splitter
here are some meter manufactures i have never worked with 600v meter you may need to use a Potential transformer to lower the voltage to work with a watt hour meter. but check with the diffrent manufactures too see what products they have and what fits your needs.
I am sure there are many more and maybe a manufacture that fits your needs better then these i am sure some one will post more information.
http://www.osaki.com/
http://www.pwrm.com/products/
http://www.emon.com/
